the sonic tower you can put just one fan but you can attach another by other methods xD and the sonic tower is even bigger than this one
would this fan crush ur cpu? i was looking at buying it but got scared cause of the weight :(
some more reviews ::
http://www.cdrinfo.com/Sections/Revi...rticleId=12986
http://www.motherboards.org/reviews/...re/1488_4.html
The only thing I'd be concerned about is bending the mobo if held sideways. You exert a lot of pressure when you screw down any heatsink, I don't think weight would matter much.Quote:
Originally Posted by lastdon00
Guys, it's mostly aluminum, this thing weighs a lot less than an SLK900U.
Originally Posted by EnJoY
Wrong -
SLK900U
570g (heat sink only; for AMD)
587g (heat sink only; for Intel)
TT Big Typhoon
Weight 813 g (28.70 oz)
the SLK is half the weight lol
I have mine mounted and sitting sideways in the case, most the weight it in the base, the top is aluminum but the base is a huge slab of copper.Quote:
That's good to know. I'm pretty sure mobo's are supposed to withstand that kind of weight, but I always lay my case flat so how would I know :PQuote:
Originally Posted by dnottis
I never could do this with the XP90 - priming it now...still cant prime at 2.8.
http://www.3dxtreme.net/other/CPUS/3...20037/2800.jpg
This is 1:1, my G.Skill 4400 LE tops out at 304, memtest errors at 305 so I'm waiting on OCZ PC4800 to come in. This Cooler rocks!
http://www.3dxtreme.net/other/CPUS/3...4%20stable.jpg
Im glad everything is working out for you ok there dnottis...you been through hell with all those cpus...I remember that...
u guys worry too much :)
i have had a tall thin 1.1kg heatsink (hyper6) hanging off my mobo for 9 months and it hasnt snapped yet (crosses fingers)
I'm also glad to see things are looking up for you Dean cause you have had one hell of a time in the past :D
Wow, I might actually get that. Although, I wonder *how* much better it could be over an xp-120 with a 145cfm fan (my setup) ;)
Nice though, 2.73ghz, thats hot.
Very nice dnottis. Will this work in a k8n neo2 pt m/b? I cant find any compatibility list at TT website.
thanks.
Your correct I have the Silent tower and it is massive.(won't even fit in narrower cases), its almost 12" tall. I've had it for 6 months and its great, my temps are as good or better than those using and XP-120 with fan.Quote:
Originally Posted by leviathan18
Holy crap! That thing is huge!
Originally Posted by dexth77
It should, the base and heatpipes aren't that big - its 6 inches above the mobo that it's wide ;)
wow thats a huge heatsink!!!
i bet if you lap teh base mirror smooth and lap the cpu slug mirror smooth use artic silver 5 very little of it and put a delta or tornado 120mm on there you will beat 90% of watercooling out there but with more noise.
try that and 1.65 or 1.7 volts and i bet your cpu will fly
________
Pissing :banana::banana::banana::banana::banana:
Originally Posted by brandinb
I have loaded SNM at 1.65 and 2.8 GHZ and still am maxing load at 42 deg c. I've seen another 120MM that I want to try it's 72CFM @ 21DBA...20 CFM more and still silent!! :) I am already using a thin coat of as5.
I have a feeling screwing down the Cooler is allowing the cooler to make better contact with the CPU though, this may be partially why the temps are so good with it over my XP90.Quote:
Originally Posted by DamienKC
It works I've been using the big typhoon for a month on the k8n neo2 ;)Quote:
do you think you could handle this fan??
http://www.svc.com/fba12g12u.html
its 115 cfm and only 45db thats 11db less then a tornado that wouldnt be too bad
plus its only 10 bux hehe
________
NEVADA MARIJUANA DISPENSARY
ok that fan i linked to was wussy hehe
http://www.sidewindercomputers.com/de12tfexhisp.html
its 220 cfm and 65db
make sure you have weights on your mobo when testing so it dont take off
________
Motorcycle tires
Be prepared to wear ear muffsQuote:
dnottis, i can't remember but, are you from the uk? if you are where did you pick the heatsink up from, had a look around and can't spot it anywhere.
