if this is the case, possibility i get winbond ram is high, but how do u explain i can get low voltage at high fsb? etc ddr600Quote:
Originally Posted by varzmaster
i dare to open the heatspreader, void warranty :D
It's not necessary to remove the heatspreaders (aka voiding warranty :D)... just read the rev on the label carefuly. ;) If it's 4.1, they're TCCD's. If they're 1.4, they're UTTs. That simple.
It is possible that for the 4.1 rev, Corsair may have used other Samsung ICs (like TCC5)... which may be a good thing. I got DDR606 2.5-4-3-8 1T on A64 (Abit AN8) and DDR566 (283 MHz) 2.5-3-3-5 (with PAT) on Intel (Abit IC7). Those TCC5s are used in rev 4.3 of the Corsair 3200C2(PT). :)
You make me laugh :D Are those memtest screens supposed to show some kind of stability? I hope that TCC5 can do much more than that. :stick:
Well... they are supposed to do just that. But I think that's beyond you. :rolleyes:
Now seriously. Are those settings Superpi32M stable? I've wrote that because 2 memtest #5 loops proves nothing. I had one Plat rev2 stick faulty, which can't do 2-2-2-5@200. It gave errors only at the 20th-30th loop of test5. Nonetheless, using win XP normally (moving files, deleting, etc.) it won't last more than 5-10 minutes without a reboot.
PS: glad you had luck with your TCC5.
That (with all due respect) is JUST A HEAT ISSUE! ;) And yes... both sticks are SPI stable at about DDR610 (so above what the screens above show). :)Quote:
Originally Posted by amrgb
Also with all due respect, it is NOT A HEAT ISSUE. My memories do not exceed 32ºC in memtest #5 loop even after an hour, with an ambient temperature of 27ºC. I have a DFI Nf4 and a XP-120. The lower stick is cooled by a Delta 190CFM on top of XP120 and the upper one is cooled by a dedicated 5000rpm 70CFM 80mm fan. If this is heat issues maybe I'll have to consider moving to Alaska :D Also, I've tried vdimm from 2.6v to 3.0v.
I entirelly trust the temp probe, moreover sticks were cold, not even warm. However, when I sent the sticks to RMA, i noticed that the heatspreader was already not making good contact with the chips at the stick endings. If it was a heat issue, then it was caused by the heatspreader (they can do more harm if something goes wrong than good if everything is ok).
i am sure it is rev1.4, see thisQuote:
no more comment from u guys??
im testing this version 1.4 RAM (2x512MB),
last time can boot up with CL2.5 or CL3,
now only able run with CL2 ~!!!
CL2.5 or CL3 cannot go into window,
hang at the verify DMI BIOS sceen there...
what's the problem ? :(
2-2-2-5 1T, 2.9v can go up to 210MHz,
priming now ...
result tomorrow morning.
