over 5000MB/s unbuffered is pretty damn insane :toast:
Great overclocking there Tarmo :D
Dude that ram is nuts! :eek:
So whats tricks you gonna try next to get to 1GHz DDR?
(Also you still using the corsair heatspreaders?)
Get more voltage for cpu. That should be it ;)Quote:
Originally Posted by b|gf|sh
It´s almost impossible to remove heatspreaders from this kind of BGA ram.
There is a bigger chance to kill the ram than not to kill it :)
The memory is not the problem, cpu is. Thats why there is no SuperPI at this time.
Insane to say the least... great work once again :toast:
Thanks guys :toast:Quote:
Originally Posted by Bennah
At 2.3v and using the most relaxed timmings the your ram can hit 1000Mhz ? Like in the Anandtech P5WD2 review ?
The Stilt... this is awesome man... any pics of the setup?
1) are those XMS2 or TWIN2X?
2) can you also run a memtest86 and tell us the benches of L1,L2 and Memory please!!!
This is a TwinX kit.Quote:
Originally Posted by Byron
Running memtest won´t help that much since it will be corrupted after ~ 4.3GHz.
Damn, those results are plain crazy... :slobber:
Thank you for making my last day of wait simply intolerable...... :D
Thanks,
Why memtest86 will be corrupted :confused:
32-bit limitation kicks in when cpu frequency passes ~ 4.3GHz.Quote:
TARMO, I'll send you the Asus P5WD2 Premium sample BIOS later today :cool:
The Stilt,
amazing results... looks like DDR2 is now at the stage it IS better than DDR... at least in your hands it is.
Congrats!
MAn you need an ES chip...contact Fugger I know he has one...so you can run 1:1 with a lower multi...that would be CRAZY...GREAT JOB THERE!!!
Dragon
Awesome results indeed! Having the same rig - I'll have fun trying to chase your scores...DId you ever get that bios?
How high can they go with CAS3?
that is very nice man!
great clocks you have there, congrats :toast:
Hi
Yes this is a pretty nice board!
I broke 1120MHz with my Centon mem - http://valid.x86-secret.com/show_oc.php?id=16918
When I try using the Setfsb, that you link to, I just get an error?
I have a couple of Bios for the board, and 1 of them supporting 1066Mem freq, let me know if You want one.
I might just want one later. Maybe I'll catch you on tweak.dk later tonight. So far I'm installing and updating windows.... Just did a quick test to make sure new board, memory and psu was working properly, so I very conservatively ran memtest and installed @ 250 Mhz fsb and DDR675 @ cas 3-2-2-8 and 2.1V in the bios. No errors an the memory isn't even warm at all. Nice. Memtest said 3558 MB/s I think it was, this is with 640 @ 4 Ghz and -29°C in bios.... :DQuote:
Originally Posted by Soltani
Pm sent :)Quote:
The Stilt > Did you get the Vcore issue sorted? I can't seem to get the Vcore to go over ~1.496 in the bios, regardless of setting from around 1.45V and up it just stays the same....
Thus I'm stranded @ 290 Mhz fsb and 4647 Mhz right now. Could probably go a bit higher as this is completely stable, memtest, prime and everything.
Memory running @ 2.3V in bios @ 4:5 divider 725 Mhz cas 4-2-2-8, memtest86 ver. 3.2 shows 3886 MB/s, no 32 bit bug in this version as far as I can tell. Would be awesome to see what you could score with that insane mem speed.... :slobber: :D
Many thanks for the bios Mr. Soltani :toast:
With little eased timings and with silly low voltage (2.38V) I managed to do this :D
That was just an appertizer. More to come soon ;)
:eek:Quote:
Originally Posted by The Stilt
I know what I'll buying when I get payed then
Any plans to try out the new asus intel nf4 board (or any other new intel boards for that matter)?
pld dude :cool:
Nice clock!
Hehe You are getting close to my 1. place - http://valid.x86-secret.com/records.php
Do You know why I get this error when trying using the setfsb?
I´m also getting the same error.Quote:
The error has something to do with the different bioses.
Abo designed the program for boards that use retail bios. It think these unofficial bioses change something in the pll interface.
