MB : DFI NF4 Ultra-D
Mem : 2x256mb Twinmos BH-5 (old) 304WE and 307WE , W942508BH-5
Bios : 310p
277Mhz 2-2-2-5 @ 3.93v
Will also try some Twinmos Speed Premium 2x512 BH-5 tomorrow
Bios : 310p
TwinMOS SpeedPremium CH5 UTT, DFI NF4 Ultra-D, Winchester 3000+
263 MHz, 2-2-2-5-1T, 3.4V, 263 HTT and Memory running at 1:1
Prime95 Custom Blend Stable! (and everything else)
Don't have A64 Tweaker for this setting, I wasn't using that program at the time and I don't have these sticks any longer. But here is a setting for which I do have A64 screanie.
TwinMOS Regular (non-SP) CH5 UTT, DFI NF4 Ultra-D Winchester 3000+
252 MHz, 2-2-2-5-1T, 3.2V, 280 HTT and memory running at 9:10 (252)
I dont' have SuperPi 32M rans with these modules, but Prime95 Custom Blend is a far more rigorous test.
New SuperSystem:
3700+ SD cabbage, 4x 512M sticks Twinmos TM400II UTT "AA4T", DFI Ultra converted to SLI-D, 5V memory jumper, OCZ 520 Powerstream, 2x 36G raptor raid0, X850XT, mod'd AMS CF1009 case, NEC 3520A 16xDVD burner.
Stock HSF on SD, AS3 used for all. X850XT at stock clocks. SD at 250Mhz x11, 250Mhz HTT (x3), 1.250 + 126% Vcore, Vdimm @ 3.4V, 1.4Vldt, 1.9Vchipset.
2Gigs @ 250Mhz 1:1 2T 8,2,2,2.0, bankinterleave ON.
PCpitstop... 2233 (my Infinity is 1806)
32M Superpi mod 1.4 26m54.156sec
3D2K3 13011 (cpu 1337)
3D2K5 5931 (cpu 5611)... GPU Mhz dependent, Infinity sys gets 6300+
3D2K1 30159
HDTach 218MB/s burst, 116MB/s avg, 8.0ms access, 10% CPU utilization
Atto 0.5 10180write 27469read
Atto 1024 127522write 107440read
SSoft CPU 12755/5638
SSoftMEM 6004/6014.... 8000 theoretical max, 2T hurts here 75% rating
Everest 2.0 6635 (BI OFF 6425) read, 2300 write (BI OFF 1762!), 41.9ns lat
BankInterleave has a huge effect on WRITE benchmark time, good thing it works.
Thought it'd be easier list numbers than finding an image host.
@hovo73,
Could you please run Spi32M? I know that if Prime95 runs then SPi32M would too, but we need SPi32M results. For reference ;)
@uwackme
Hey, what's up! Good job, 4x512MB :slobber: Would please add a screenshot for 32M? Just convert it to .PNG (even with Paint) and attach it to your post. The limit here is 200KB, so you should have no problem getting it within that limit ;)
Thanks :toast:
No sorry I can't. I don't have those sticks any longer. Does that mean it is not going to count?Quote:
Originally Posted by bachus_anonym
Guys I'm such a damn moron I forgot to open the A64 tweaker page in my screenshot. Can I still post my benchmark? I did include the CPU-Z though.
260 FSB 32M SPI run
Ill put up a 32M sreenie later today B.
I ran my 4x 512M BH5 in this same system, 225Mhz is max stable point. BH5 also has a coldboot issue, a real pain if I turn power completely off....have to remove all but ONE stick, power up, then warm-power down and put the others in.
My other 4 sticks of Tinwmos... 3200 SP... have vrious troubles in this system. 2 Sticks are voltage averse and flake out over 3.25V, one of the high volt sticks is only good to 240-245Mhz, the 4th stick is a 260Mhz keeper equal to the original 4 sticks of TMII that do 260Mhz 4x512M 2T.
I tried HELLFIRE's mod'd 5/10-2 bios, is good so far for 3.3V rather than 3.4V operation of the rams. SO same speed at .1V lower setting.
The BH5 cold boot thing was on all versions of the bios...1/25 3/10 5/10-2 and Hell510-2. The system hangs at 3 LEDs on cold boot, like it cant make the CPU test to MEM test transition. Wondering why, but only Oskar has the source code to the boot code, so I have no idea.
Hellfires modded 510-2 BIOS? Where can I get that?
3200+ venice @ 267*10
OCZ VX PC4000 @ 3.5V
DFI NF4 SLI-DR MOBO
6600 GT
oops
http://webpages.charter.net/mlanter/SD271PI2231.jpg
2x256 Buffalo@3.5
DFI ultra-D
Back ;]
282,7MHz 2-2-2-5 1T 9x314 div180
@ 3,6v
What, you didn't believe my 271mhz result anymore bachus;)
http://www.xtremesystems.org/forums/...174#post860174
hereQuote:
Originally Posted by Tibu
again...
284,4MHz 2-2-2-5 1T 9x316 div180
http://members.lycos.co.uk/m4rd0k/xs...25-33_mini.jpg
Full Size
@ 3,66v
3700+ San Diego at 267x10 @ 1.36 VCORE (CPU does 2904 @ 1.568)
2x512 XMS3500, 2-2-2-5 @ 3.63 VDIMM
DFI NF4 Ultra-D
Corsair HC200
510-1 BIOS, orange slots
Check out the 32M time at only 2671 mhz :).
I have seven 512 XMS3500 sticks and the pair above is the WORST! I tested each stick in SC on the 4PCA3+ board and they did from DDR504-519, 2-2-2-5 at 3.28 VDIMM. The sticks above did 504/506. Been burning them in for 1.5 years.
Not bad for ram circa 2002 ;). One stick has BH-5 on one side and CH-5 on the other (at least the nibs are different on one side).
Managed to get them trough at 279.3 @ 2-2-2-5 today.
http://home.online.no/%7Eandr-sei/Fo...I/279xs32M.JPG
http://pics.bbzzdd.com/users/chinkgai/superpi2620.JPG
i thought the 754 list was lonely so i decided to chime in :toast:
cpu is at 1.508v (1.45x1.04) and the ram is at 3.4v
2 x 512 "1A4T"
bios 510-2
2500mhz , div 180 - 250 2-2-2-5-1-T - alpha default - 3,4V
http://img.photobucket.com/albums/v3...2-2-5-1T-3.jpg
Now I will try to play with aplha :D
OK b_a, I'll give you what I got atm on my 2x512 OCZ VX 3200. It's probably worth noting that these 3200's were purchased well before they started binning for VX4000. Time could be better, but I was doing this purely for the sake of the thread, not to beat any of my old scores or anything, not that the Venice would. I think with these sticks right now, the only thing keeping me out of the 270's is VDimm. I'm running off a jacked up +3.3V rail and 3.55V+ seems to be the limit for stable VDimm. 3.6V droops and running off the +5V on this board just doesn't work well. I may give that another shot though. I should be back in here later this week with some Redline results too. :)
http://mysite.verizon.net/res6otqr/s..._25.30.344.jpg
Heres redline...with all candies on and no opti. and ultra-D with 55BN-SD @ 1.32V...
http://img210.echo.cx/img210/1760/screenshot0675cd.jpg
i can get some old corsair bh6 @ 250 @ 3,3v for 60 euros
woh much do you think is stable @ 3,6v
As stable as i have got it so far, adding voltage at this point seems to do nothing.....Redline 3.5v 265 2-2-2-5
All entries have been updated. Thank you!
@Clevor,
As much as I would like to add your result to the list, I can't. I need to see SuperPi, CPU-Z and A64Tweaker on one screen. Not just cropped seperate windows. I'm sorry :( If you could re-run it, then it's awesome :toast:
@chinkgai
linky no worky :D
