Honestly, I think that AndyOCZ was mistaken about atributing failure of those OCZ EB sticks to the PSU, only because it had 20-pin connector. And that resulted in "sort of" too harsh response from Angry Games, in my opinion.
The only difference between 20-pin and 24-pin is four more wires, that's it. Those wires come out from the same "pack" that the rest of 3.3v/5v/12v. They don't have some separate circuit that they're part of.
Look at the pics I attached. This is the inside of 24-pin PSU. You might notice there are some separate wires soldered to the board, though. Don't get too excited :) They are for SATA connector :)
http://www.xtremesystems.org/forums/...id=29763&stc=1
http://www.xtremesystems.org/forums/...id=29764&stc=1
http://www.xtremesystems.org/forums/...id=29765&stc=1
The whole issue with PSUs for NF4 boards is not the 24-pin that is needed but a solid, high wattage PSU with about 30A on 12v rail.
EDIT: I also think, that there was a good reason behind putting additional molex and FDD connectors on the board. Maybe DFI put it there in case some folks would not like to switch to 24-pin too fast and still use their 20-pin PSUs? I would think so, as ATX 2.0 was bought up for PCIe support. So even If one has GOOD 20-pin PSU, he could still use it with PCIe video card. To be safe, just plug extra molex connector into the board and voila! This would provide additional juice for PCIe slot, instead of those extra 4 pins... THat's just my thought, though... :)
