*cough*
I disagree with some of your comments DS...
Regarding wire size... depends on insulation type, air flow, and density of the wire bundle. I would
not suggest you try putting 18A thru an 18Awg wire in a 24-pin wire bundle ;)
There is also much more to power distribution than current capabilities... I'll just refer to a previous thread on this:
The old thread is here
Regarding differences
noticed in testing... keep in mind results
will vary depending upon what is in your system and loading. Besides the things in the above referenced post, IR drop, particularly on the +12V rail (of which there is only 1 of in a standard 20-pin cnx) starts having affects with heavily loaded systems. There are also distinct benefits to extra
seperate ground connections all the way back to the supply that have nadda to do with current
carrying capabilities ;)
Peace :toast:
