Eva is 100% right. In my case, and this is 2x256 LA TCCD bank interleaving makes it more stable not less. As far as performance goes I don't see any difference.
of course :)Quote:
Originally Posted by joe2004
bank interleave disable, unfortunately did not solve my issues. oh well.. i could preorder venice;)
Man I love posts like these, makes me so happy venice is coming out. I'm going to be able to move to an A64 setup for dirt cheap.Quote:
Originally Posted by pershoot
LOL. You can buy my Winchester when I sell it in a month or so. :fact:Quote:
Originally Posted by jumanji969
same here , ill have my 2.7 ghz winnie for sale once i get my venice :D .
Hurray! Cheap part for poor people (me)!
On topic, i havent really pushed my memory all that far (around 260mhz cas 1.5 or 2) but i left bank interleaving on with my bh5 memory. Everything went fine, up to there anyway.
Cas 2.5 wont run no matter what though, i tried getting 285 1:1 with cas 2.5 but my memory doesnt seem to wanna run at cas2.5, maybe thats whats causing it? Ill have to try that when i get home
BH5 has big problems running anything but cas 1.5 and 2.Quote:
Originally Posted by Ailleur
Hey guys, here's another tip -
I just got in another DFI Ultra-D, since the other one was having issues. I put the new one together and left the chipset cooler / TIM in tact. I was having random freezes at 300 FSB. Last night I yanked the board, removed the terrible yellow putty on the chipset and replaced it with a nice coating of as5. I can now prime and super pi32m at 300 FSB x 9 with only 1.53 volts. Very happy with the new DFI Ultra-D, the last one and the RMA had some issues. The first one was the worst - random reboots, problems with USB etc. I had done this with the first one too, but sometimes a bad board is just a bad board.
Bottom line - removed the yellow putty on the chipset and replace it with some quality AS5 (or comperable TIM).
wow i still have stock what ever paste under my DFI NF4 SLI-D's chipset heatsink heh
tsk tsk ... :slapass:Quote:
Originally Posted by eva2000
That TIM material it comes with is like gum! That is 1 of the first things I do when installing a new system, yank the chipset cooler and replace the stock goop with some AS5 (in the case of NF4 chipset or Intel chipset) or Ceramique with the NF3 type chips.
hehe but that hasn't stopped me pumping out the numbersQuote:
Originally Posted by dnottis
http://www.fileshosts.com/DFI/NF4_SL...5_24264_tn.jpg
I hit 290HTT no dividers but i did notice when disabling Bank interleaving system was more stable and you are able to increase the FSB more.Quote:
But who knows maybe different memorys have different yeilds. I dont know which type of TCCD i have all i know is that its pretty old. If any1 knows how to tell pls let me know.
thanks
Originally Posted by SVTSnake
Same here but I've never seen it really affect stability like this! EVA 2000, what kind of cooling are u using?
With certain types of memories disabling bank interleave does heavily improve overclockability. :fact: For example, OCZ Platinum RevII 2-2-2-5 benefit heavily. And yes, certain mobo vendors have found this out and exploited it to achieve better O/C numbers than their competitors, especially for the purpose of web reviews. One particular set of dimms that I've tried picked up around 35-40MHz at the same timings by just turning off the interleave.
yeah BH-5 is on memory that excels with interleave disabled hehQuote:
Originally Posted by Grayskull
dnottis, i'm using MCW6002 + MCP650+MCP600 in series with Thermochill 120.3 with 3x 120x38mm panaflo 103cfm fans to cool cpu only and 2x60x25mm fans over ram modules :)
I think I need to go water - this chip did 2.8 @ 1.6 on water forthe previous owner - for some reason I cannot prime any higher than 302mhz with this chip and it's only at 1.53v. I think my limitation now is cooling.
Dean
Hey, but wasn't it that if turning bank interleaving off, you got a noticeable performance hit?
Originally Posted by mrlobber
Nah, it's slight actually. Actually I can prime at 1.53v (9x300) with it disabled or 1.58v (9x300) with it enabled. Its currently at 8hr, 45mins prime stable at 9 x 300 with it enabled.
I noticed about 200-300mb/s difference in Sandra with it disabled...but it seems to be much easier on my chip's mem controller - I gained ~20MHz. Need to do more testing.Quote:
I get 7800 without it and 7916 with it enabled. Benchmarks are up a bit too. Since it's only .08v to enable it and run stable - what the hell I'm doing it :)Quote:
Originally Posted by Gogeta
14 hours prime stable so far :woot:
This is something like running TRCD at 2. Only BH5 and UTT based ram can do it reliably at high speeds. Only a few types ram can run well and reliably with interleaving enabled.
Or is this completely wrong?
Well I managed it but it took .08v more to do it stable, must be extra load for the memory controller.
Something less than .1V on memory is basicly insignifigant. I wouldn't worry about killing it.
