And to think were still sub 3G's yet.
Badass chips.
Badass chips.
i hope to buy a 3200 an oc to 2.8ghz on water....
Can someone run 4 double sided dimms with this CPU and lets laid the speculation to rest.
OMG This must have been the fastest Sticky ever !!!
Amazing stuff PC-Ice ! But lets see some 3ghz+ results !
Perkam
i asked dave already, but i think he locked himself in his hardware lab :lol:
cant blame him though, id do the same with such a sweet chip :D
Man that's sweet :rocker:
update:
1.4v undervolts in bios, bumped up to 1.4v vcore real
how about 2950mhz stock vcore? :D
OMFG...i must be a dream :slobber: :slobber: :rehab:
very nice
it's cpu@-40° or evap @-40?
O_O
thats just beautiful. Maybe now AMD will start clock-scaling like Intel, but actually performing? :)
AMD must come out with higher models of those babies clocked at 2.8GHz+!
Nice results.....but I want to see what the venice core does with 1.7V!!!
Good lord, maybe it's a good thing I couldn't get my 3200+ when I wanted.....seems this IS going to be the chip to have...or any other Venice for that matter....fricken amazing. :toast:
Wow, that's clocking beautifully!
*grins* I wonder if the San Diego will do better :)
same here... also, maybe some more benches, please :DQuote:
Originally Posted by NoStra
2950mhz at 1.4V is insane
since its a single stage cooler by pc ice himself i think its -40°C cpu temp and not evap :)Quote:
Originally Posted by d@rkn1ko
but im not sure... i asked him already but hes busy benching :D
you mean fx57? its comming out soon :DQuote:
Originally Posted by Bloody_Sorcerer
check this thread again tomorrow :DQuote:
as i said, i will keep updating the thread :D
why should it do better?Quote:
Originally Posted by Stewie007
i forwarded this to dave as well... but as i said... :DQuote:
Originally Posted by bachus_anonym
So they perform well at low vcore...
What about high vcore?
you should also give it a run with aircooling so we can have the results of 2 different processors and have an early average :p
dave will test it with phase change cooling first, then water, then air :DQuote:
Originally Posted by kappa2001
if theres not enough time he might have to ditch the aircooling though...
i think steven who also found an amd venice on his doorstep did some tests with air, no?
http://www.xtremesystems.org/forums/...ad.php?t=56313
-40 cpu on single stage really hard
Whats its max on air though ? Thats what I want to know :D
Perkam
my mouth is watering so bad for one of these things...... I'm quite sure 3Ghz is reasonable with more voltage..... maybe even possible with a good air cooling setup..... I'll be happy to try.
Same here, I'd like to see some air and water results...as well as higher vcore results......
OMFG those are some insane clocks man!
Perkam,
I think it will do teh same kinda clocks on air as it is doing under phase change but I think it may require slightly higher volts... When I get one; its going streight under the best watercooling system money can afford! :D
I bet this chip could probs do atleast 3.1GHz...
Alec
Ty, Alec, but what cooling are these chips on ? and can PC Ice test with a Winnie at the same spec, I want to see the diff between Winnie and Venice at same speed in 01/03, etc.
Perkam
I might have to pull from the emergency fund... lol :D
