Where can I purchase this kit? :confused:
Send my your address and I will send you a couple sets of the insulation. and a other parts.Quote:
Originally Posted by craig588
NO Charge.
PM me..Quote:
Originally Posted by NoX
wow!
just what i was looking for
what is the top made of?
and would a stable mount be possible if the evap insulation was thinner than the width of the bolts?
Sintra
http://www.cuttingedgeinc.com/ref/matPAGE1.htm
I have tested it to -120c many times.
for single stage, thinner insulation can be used or trimming of the supplied insulation is also possible.
great thread for first time phase change users like me.
all i need to do is to buy a chilly1 single unit...
Really Really nice,is that foam closed cell neoprene?
The foam is standare refrigeration insulation and is closed cell.
so am i to understand that you can run with this type of insulation 24/7? surley something more is needed?
Fugger,
What about insulation on back of mobo behind CPU socket? Is that not necessary?
Yep, shown in one of the pics I use 1/2" closed sell foam. It is what I used on the cascade and handy for that example.
Thinner stuff can be used or even two layers of foam tape.
Whoops, guess I wasn't payin attention :DQuote:
Originally Posted by FUGGER
Is Neoprene closed cell, Fugger?Quote:
yep
Would it be possible to get a video card mounting guide as well in the near future?
And maybe a socket 478 mounting guide? :p:
Oh hell yeah! Im already drooling over a possible Chilly dually. :slobber: :slobber:Quote:
Originally Posted by Nerm
http://www.xtremesystems.org/forums/...chmentid=27122
wath I see!!!! :banana:I see you found the plastic to protect the neopreme on the evaporator Harms...... I want !!!!! :banana: :toast:
I'm also searching for this black hoses, where I can get these?
I don't know for sure but it looks like armaflex with normal wire mesh around it. Like the stuff you mesh you psu cables with.Quote:
Originally Posted by cold_ice
Yes but the PSU things are much smaller, can't find this big diameter
Send me your address and I will send you some insulation and the wrap..Quote:
Originally Posted by detonator
That looks so much simplier than cutting a 4''x4'' inch of closed cell foam, cutting the outer hole out. Then with the center you just cut out, cut another hole to fit inside the enclosure. Chilly, how many big and small donut foam do you have?
Looking good, i cant wait for mine :D
cool:)Quote:
Originally Posted by chilly1
address is still the same, but I will refresh!! with that plastic wrap is just fantastic pure class!!!!, I hate to see ruined and cuted the neopreme around the arms of the evaporator....man llike this is pure class chilly1 all the way;)
