400 = 1:1
333 = 5:4
266 = 3:2
Try running 5:4 and see what you get. Then run some benchies at 1:1 and 5:4 to see what gives you better performance, if you are concerned with that.:)
400 = 1:1
333 = 5:4
266 = 3:2
Not much luck. I guess my problem is the cooling. It can't be the RAM unless ddr500 just isn't enough. ADATA manufactures their own chips so they should be top notch. If I ever get the money I'll get PC4400 or something. Maybe some OCZ.
I had the same problem!
I had a kit 1 GB mushkim pc4000 and Ι did not go over 257 mhz fsb with any divider(1:1 ,5:4,3:2 ) I tried :(
I tried with 2x256 MB corsair ( BH5) at 270mhz 1:1 with 3,7 volts and everything was ok :)
3.7?! on what and how?!
on P4C800 E Deluxe with ocz booster! :)
3.7 through your ram?! WoW. Talk about durable.
It was only for bench! Super pi 1M 29 sec @270 mhz fsb 1:1 at 2 2 2 5 pat enable corsair XMS3200 2X256 MB with 3,7 Volt with ocz booster !
holy :banana::banana::banana::banana:, does that booster work on any ram?
It is only for ram .....which loves Volts!!! :stick:
I also have an asus p4c800 e deluxe rev2 and a P4 2.4c. I'm a noob in soldering but i will try.
A few questions:
Do i have to do both vcore mods or only the droop mod ( my vcore is drooping)? I don't understand why u did a vcore mod (you can set your vcore pretty high in bios)
Do I have to use tin?
thanks
marre
You have to do only the Vdrop modQuote:
Originally Posted by marre
You don't need the Vcore drop because you have a Northwood and this mobo is able to give to Northwood as many Volts as you want, from bios.
The problem is with prescotts....the mobo can't give more than 1,6 volts from bios!
beware...if you want to run a very high vdimm and 3.3V rail, put some sinks over mosfets arround CPU and some fan to cool them.
I burned one mobo becase there were no cooling running vdimm @ 3.6
Originally Posted by b|lly
:slobber:Quote:
Originally Posted by micdoc
I checked in CPU-Z ON MAINBOARD TAB.Quote:
Next to Model it says Rev 1 .xx but just below that is says Rev A2
What version do i have?
I noticed your using Vantec tornado i have one ITS SOOOOO LOUD. What kind of fan switch do u use? or can you recommend a better and quieter fan.Quote:
Originally Posted by Dynasty
Look between pci slots on mobo will tell rev.# below the EQuote:
Originally Posted by irfs
Are these mods valid for a Asus p4p800 deluxe.
Go here. Please, note that for the droop mod on the P4P800 has changed after Asus made a revision on it. Do a search here for it, and you'll find the other way to do it, if your revision is different than the one on that site.Quote:
Originally Posted by elec999
Does increasing the 3.3v rail effect the temps of the mosfets?
hello everyone. im new here. this looks like a great forum for modding, so i registered.
i am in dire need of the vcore mod on my p4p800 e deluxe. ive done vdroop and vdimm, and they both work excellently.
i attempted the vcore mod by soldering a VR to pin 8 (fb) and ground on the ADP3180 IC, but had no impact on my vcore. ive never seen anyone actually say that it works on their p4p800 e dlx. apart from the p4c800 dlx, i dont know of any mobo that has the same ADP3180 IC. any help on this matter would be greatly appreciated.
is there perhaps a very fine line in the VR adjustment that enables vcore change. the volts stayed the same for me as i reduced the resistance toward 0K, but got to a point where the screen goes blank and wont reboot till up the resistance a little.
:fact:
ADP3180 is used on the P5P800 as well as the P5AD2-E
-CaT
thanks catalyst. ill look for vcore mods on those boards and compare.....
Does this mod work on the P4P800se ?
thanks :D
For P4P800 mods go here. Compare the boards layout and see if it works for you.
are these mods the same for p4c800 NON E-dlx?
