jesus christ that clocks well!!! Awsome stuff man; bang those voltages up and lets see her past 3GHz! :D
Um, how come in post #13 CPU-Z says 1.4v, but CBI says 1.2v? Does Kunaak have a checker for CBI?
Ok, 2800 is a breeze for this chip at close to default Vcore, but anything beyond that required much larger voltage increases.....
Here's 10x290 - In bios, I believe it was set to default vcore (1.4) + 5%
http://img57.exs.cx/img57/5968/10x2909pv.jpg
Damn... when are these available?
2.9 GHz @ 1.47 still nice !
Show us some 3 GHz action and max this chip out !
Then test the other one :cool:
you're putting out these benches pretty quick. if the time inbetween posts is how long it takes you to get to that speed, i'm impressed, though concerned with the long term stability :toast:
dddddaaaaaaaaaaaaaaaamnn
anyone in on robbing AMD w/ me?? :banana: :banana:
Originally Posted by ozzimark
Clockgen Perhaps :)
Ummmm, I think he did these last night and is just putting the screens online from work.Quote:
s7e9h3n !
can I have your paypal account address ? if i can - just tell me how much $$$ will make you send this baby to me ....
i believe hes on phasechange..
So these results Will more then likely differ on air/water cooling
Im still waiting for prim95/3d testing.. superPI isny to much of a stable test, unless u run the 32m test i guess..
yeah, you're probably right.Quote:
Originally Posted by clockedOut
dissolved: he said he's on the stock fx-55 cooler.
You didnt read when he said he was using a stock FX cooler?Quote:
Originally Posted by Dissolved
Nice results! cant wait to see these hit zzf and newegg :)
I do like to know in which price range these nice Venice cpus will be in.
*regged* also here
anyway he's on air ;) A64 FX55 stock cooler just with a different fan tho'..not sure :D
Now I've only got a couple of more screenies. Since I didn't want to take too big of a risk (yet) with this chip, I limited the Vcore I was feeding it. Te highest I used was 1.45 + 8.3% in bios. This was the Vcore used for these last two shots. As I now look at them, I'm figuring I could give the 3800+ ~.1 more vcore and be relatively safe in terms of temps (voltage, on the other hand, may not be as safe.)
SuperPi could not finish 1m at this voltage, but I'm sure it would be fine with a little bump.....
http://img57.exs.cx/img57/5921/10x2955oq.jpg
:slobber:
This is SOOOOOO awesome!!! However, lets remember my FX55 benched 3D on AIR at 3000mHz++....this is a great improvement over MOST winnies.
C
With those temps, i´m sure 1.6 would not be at any risk....:)
hmm, so it's fine up to a certain speed, then any more voltage is kinda a moot point. seems typical of the 90nm chips i've seen. time to switch the thing over to the phase change.
How much are these chips going to be?
I never heard of A64 dieing from too much voltage, if the temperature was right (e.g. under 50°C AIR).
Try to run 250x12, it'll be easier for CPU than 300x10.
And remember that you have 2 chips, not one :toast:
the same as the current ones + vendor price gouging
I'm Hoping the 4200+ ca bench at 3.05-3.1GHz on air
I'm dreaming :D
i wonder who can answer this questionQuote:
Originally Posted by chunkylover77
anyway from some forum..i've heard they selling the 3800+ Venice around 600 euros
