I think you'll find them at Tic Tac's website (or the site linked in Tic Tac's sig), here. :)
There definately does appear to be a random problem sometimes with keyboards, though I actually found plugging it into the USB rather than the PS/2 helped. Sometimes I'll go into the bios and it will freeze, even if the overclock is minor, though I must admit I have come to expect little glitches like this from Abit until they hone the bios and the board has been "broken in". It certainly overclocks very easily, which will be very good for my sister, who's the one who commissioned me to make her a new system :D
My major concern right now is how to get MBM5 to work in it.
***Crucial Update***
Do not i repeat do not try to volt mod this board. I sucessfully modded the boar booted at 2.8 ddr 1.4 vtt then precedded to push it to 3.2 drv and 1.6 vtt when all hell broke loose long story short my board failed to boot any more by the power switch so i jumped the psu and it came back to life however now the volt readings are all innacurate and the board is stuck with 4.0v vtt no matter how low i turn it down via 1 k ohm pot. long story short the volt mod seems to have killed a voltage regulator of some sort.
sorry to hear that... :(Quote:
Originally Posted by chew*
anyway new board support 3.55V vdimm :woot:
have you read this thread?
http://www.xtremesystems.org/forums/...ad.php?t=62087
yep wish theyd put out a an8 fatality .v2 though i dont like the sli board layout to muchQuote:
Originally Posted by tictac
it seems i am not the only one with a temp problem on my motherboard...............when do we get a fix for that as there is no way in hell you can run any AMD CPU at 80-85C as it would blow up before you can say Abit
Originally Posted by clockedOut
Bios15 is a disgrace. No 3d apps work with this bios it just causes a bsd with the error message about nv drivers having an infinite loop problem.
So much for the new bios with X2 support. :nono:
any more reports on bios 15 ?
Same here, my AN8 Ultra will climb upto an indicated 105C under load - and heatsink has good thermal contact and is only warm.Quote:
hi... :wave:Quote:
Originally Posted by b00sfuk
:welcome: to XtremeSystems.... :cheer:
My winchester was hitting 96c on my AN8 Ultra till I reseated the HSF and now it's at around 70c which is about where it was on my AN8 v1.0 :)
hi jsut got this board. an8 ultra.
few questions
1)whats average FSB achieved? i have a 165 and want to get alot of potential
2)what are safe voltages for my an8 ultra chipset?
most AN8s will hit over 300 external clock without touching the chipset voltages at all.
so what voltages do you recommend safely for my nf4 ultra chipset? passive cooling with AS5 . i want 333 fsb for 3 ghz with opteron 165.
