Originally Posted by cadaveca
the a64 has one htt lane, which is bi-directional. 16bit, 2-way.
the FX have 2 dedicated lanes 16-bit one-way, although from what i understand, thay can be two-way, but i don't know for sure.
With the FX having dedicated lanes, this increases the overall possible bandwidth of the chip by huge ammounts...rather than 22.8gb switched bi-directional, it's 45.6gb possible. These seem like large numers, but the chipset has to support a multipler to get to the upper reaches...2000mhz on nforce4 is = to what, 20.0gb? easier for the FX to utilize the most of this bandwidth, because of the 2 lanes.
The opteron uses the third lane to connect to the second cpu, and only differs from the fx in this way. managing all the communcations explain the slight drop in performance from FX to opteron.
anyways, even the FX and opteron, limited by chipset as they are, are not using most of this bandwidth. so it makes sense to just drop in another core to make use of all that extra, and even though the crossbar is there, adding latency, keeping the 2 active lanes means that the small amt of latency should not matter, if you go to two lanes bi-directional, OR dedicated.
