Just found the OCZ PC4000 Gold VX in stock here:
http://www.memory-configurator.com/brand/OCZ.html
-jayo
-jayo
As with BH-5 lower timings win on all but Sandra buffered
http://www.anandtech.com/memory/show...px?i=2369&p=12
Tight timings is what you are looking for when Benching... For 24/7 and "not so heavy" benchmarking go with TCCD...
why? why is tccd better for everyday settings? :confused:Quote:
Originally Posted by skate2snow
Originally Posted by saaya
Not everyone is willing to run their memory at +3.2V for 24/7 use.
Therefore, I think that TCCD is better for everyday usage. Lower volts, able to reach higher HTT at 1:1.
Memory that require Overclock (high HTT) like gskill DDR600, you need a good chipset (mobo) and CPU (memorycontroller).Quote:
Not every (eg. winchester) will take DDR600 1T.
For people buying this new memory, make sure you got some new rev. memorycontroller to hit that DDR600, otherwise you can always run DDR550 as rated.
Maybe he mean you only need voltages lower then 3v to achieve DDR600.Quote:
To run with winbond you need voltages higher then 3.5v to match DDR600 1T.
^The VX will definetly beat ram thats at 2.5-4-4, it would probably beat those timings even if the TCCD was at 330mhz, the idea is that those timnigs should be more of a stable low point for this ram, and hopefully it will run better timings or more MHZ, for me, VX\BH is where the party is at, unless you dont like running high volts...
i hope gskill has as good an rma dept. as OCZ when these hit the market. I see all the people complaining about regular rams not hitting specs when it is their hardware and not the ram, but now saying ddr600 1t gaurenteed is going to be comical. Like others have said command rate rest's on more than just the ram. To gaurentee 1t on all boards is just misleading, and marketing hype.
subscribed
G.Skill TCCD 440, DFI LanParty nForce4
300@2.5-3-3-7 T1
http://img136.exs.cx/img136/9373/300...idth2wp.th.jpg
W G.Skill :toast:
Update if you manage to push them further (at the same timings) :). VX @ 2-2-2-5 @ 265Mhz is superior, but if you can push these up higher, they will get alot more tempting :)Quote:
Originally Posted by XiN
Yeah, I'll try ... ;)Quote:
Originally Posted by StarvationPlan
Unfortunately I have a CBBID Winchester (max 2550 mhz, not stable) so I can't do good spi scores :(
I just hate those CBBID... I wonder why they are performing so badly...
Hmm... Is memory bank interleave enabled in that bios? Does the guarantee include enabled bank interleave? I've seen people sucsessfully run memtest, but still fail to run Windows stable at the same settings. Does the guarantee include failsafe memory operation in windows?Quote:
Originally Posted by ooztuncer
*sceptical*
This is definitely nice to see.....but for now I just wanna get my hands on an Ultra-D and a 3200+ to try out my 2x256MB of LE 431 that I've got in my NF7-S right now. ;)
Permission was not requested or granted for this link in original post. Next time ask first. Thread closed.
