How tight is your ram running also? It was ran at c4,3,3,9 @ 300 for mine, pretty bad timings for 300 memQuote:
How do you deal with cold throttle? Is it simply choosing an Asus vid card? Thanks.
Congrats LardArse, continuing to set the bar.
AC
wow awsome job! btw could i get some info on that nb cooler? :D
God!!! You made me fall in love w/ this 3.73EE more :toast:
What will be the average O/C of the 3.73EE using a Vapo LS? I am thinking to upgrade to this chip.
What do you guys think?
:toast: lardarse
did you try your gpu on air?
im gonna be benching my 6800GT on cascade soon, it does 425 benchable with nv silencer, on a hot summer day. would something in the 520-550 range be feasible?
temps somewhere from -60 to -80 depending on how well kayl tunes them :D
also have you any tips for agp 6800s? oes forcing the 3d performance level in Rivatuner work like it does for heat throttle?
My guess is that he used an Asus card or another card with an asus bios to get rid of the cold throttling problem.
Btw Lard, how many volts on the gpu? 1.75V?
congratulations bro :)
New 6xx cpus overclocks pretty good! I tested my 3,2 and it works stable with water @ 4,7
Back to mother Intel!
http://www.thelab.gr/attachment.php?s=&postid=185089
No throttle at all no need for Asus bios as its a Asus card ;)Quote:
Originally Posted by drcrawn
JSU nothing special just a 1/4HP Condensing unit on a tineee evap R22, thrown together
dragonhunter I suppose 5.2 with LS??
reject, no air.. this is a card carried forward from the Asus SLI rig. No need to fret bout temps, -40+c is just nice for it ;)
just force perf 3d, no harm as far as i can see :)
~ 1.65v in 3D
Nope none of that.
wow, very nice score :slobber:
nice cpu clock:D
Heh, yeah LardArse also got me going here, I just sold my 3.4EE and I might just get the 3.73EE. But it doesn't appear to be easily found in any online stores around here, so I might settle for a 660 instead. Gotta have something to play with...Quote:
Originally Posted by dragonhunter
Wonder how far I will get with my Mach II GT as well, but with the overclocks seen on the 6xx chips around here on air/water, I think 5 Ghz (and a little more) should be within reach.
Great results there LardArse, very impressvie 2001se also with a 6800U crd, with a x850 you'd most likely be the first P4 system above 40k... Not that being the fastest P4 in the world is too shabby either though.
Have you tried pcmark04 or don't you run that? I would love to see how that score would be, I'm betting you'd rival the top dual Xeons for the first place on the orb as well. Actually I'm pretty sure you'd beat them.... :D
Very nice score indeed Lard Arse...But for the few of us still living in Room Temperature lol, how far did you get on air with the 3.73EE ? Was it higher than the 660 on air ?
Perkam
Very nice.
After seeing the latest Intel roadmaps I thought they were going to make a nice comeback but I didn't expect a score like this so fast. I thought this was another Extremely Expensive processor.
400x14 on the Abit Fatal1ty motherboard?
I had no idea that motherboard could go so high.
What memory are you using?
Please, LardArse, get a AS8 for that 660 chip. I would love to see this combo:
320FSB, 5760MHz, 5:4 256MHz BH5/VX.
Wouldn't mind seeing OPP's gpu on that either... :D
need some SLI action on these P4 3.73Ghz EE cpus.. NF5 is bringing it?
Yeah. Though, by the time ATI brings "it" to AMD, Nvidia will have brought it to Intel and AMD already, at the current rate anyway.Quote:
But yeah thats a very nice CPU and, though as Kunaak pointed out, it may only be an OCed 660, I think it may well be a worthy successor to the 3.46 EE.
However, that brings up another point, how much WILL THIS THING COST !! :eek: !!
Problem is with Intel's pricing, and knowing that its still chipzilla, it doesnt really have to compete with the FX-55 pricepoint so you'll find a 55 for under $900 on pricewatch and the 3.73 will probably cost around $1100 :(
Perkam
and ill bet you amd will sell 5 to 10 fx55s for every $1000+ p4ee Intel does. Look around, how many p4ee owners do you see? Almost none.
Yeah but I envy the EE owners because of it :) THe FX-55 IS the be-all and end-all of cpus which seems more like a wall than a doorway to me cos back in the day when we didnt have "xtreme" cpus like FX or EE, we knew that the guy with the best rig on earth had to work just as hard to get a good benchie. Hell the only chips you'd drool at was a p3, if you had a p2 and a p4 after that, if you had a p3.Quote:
These "elite" chips create a performance vacuum that means that its pretty much useless trying to compete for the top spot with a "normal" chip. And its not the price difference I'm talking about. As long as there will the FXs and the EEs, the chip manufacturers will always have an excuse NOT to add the latest stuff on the mainstream cpus so we can drool over the elite ones. (My 0.02)
Back on topic, so Lardarse you havent said how well it does on air ??? :D
Perkam
Yes that is absolutely correct. The same thing happened to my system with a P4 EE @ 4.4 Ghz when I benched with A Gainward 6800U card. Even in car and lobby I lost a lot of fps. About 60-70 fps in both car low and lobby low, and sligthy above 20 fps in both car high and lobby high.Quote:
Originally Posted by Geforce4ti4200
FUG:Quote:
Its true for all drivers save 75.90's, which are by leaps and bounds the fastest for 2001 in my testing.
Save Nature, just about every test increased, most noticeably Car and Drago H/L.
That I cannot answer, I think 4.3G with default cooling easily.Quote:
Originally Posted by perkam
Reviews say 4.3GHz was mostely max on air with this proc.
congrats shamino! :toast: very nice!
