holy :banana::banana::banana::banana: fugger, you own
He,he,he.......4500+ unbuffered memory.....Keep on....INTEL rocks(as always did)....... :D :toast:
I had been told that nanotherm wasn't good for phase change rigs because it starts acting like an insulator at negative temps :confused:Quote:
Originally Posted by FUGGER
I take it that was bogus then? :)
btw, have you got a screenie with Process Timer and superpi unpatched? just to know how close you are to that 22s :D
I am really liking the Nanotherm now, I had perfect core contact. evident in the lack of thermal material present when I seperated the block and cpu. I can dismantle immediatly after shutting down. Seperation has never been easier.
Shamless Nanotherm plug.
A64 has been showing those speed even with DDR1, but not with those kind of timing. A64 got very close here with 1:1 timingQuote:
http://xtremesystems.org/forums/showthread.php?t=53051.
but with loose timing 2.5-4-4-
DDR 720 here http://xtremesystems.org/forums/showthread.php?t=48626
but with similar loose timing 3-5-5-
What about memtest unbuffered MB/s.......?...... ;)Quote:
Originally Posted by agenda2005
39 sec. memtest isnt stable i dont think...
Well, I will answer your question first and then give my opinion about what I observed here.Quote:
Originally Posted by hipro5
The memtest unbuffered uses computation that occurs in a short burst and therefore ignores the weakness of the overall system architecture.
Here is the reason why you see the difference between P4 and A64 results.
P4 uses inclusive L2 cache arcitecture; while A64 uses an exclusive L2 cache.
Inclusive cache is faster and have lower latency but suffers alot of limitations.
Exclusive cache is slower , but more flexible to increase.
The consequences is that L1 cache in P4 has to be really small 8KB or 16KB to be effective.
L2 cache in P4 can not be extremely large otherwise diminishing returns will set in. This is why intel cannot increase the P4 L1 cache arbitrarility. I wil leave details and not go into engineering details.
For A64, with exclusive L2, you can have a bigger inclusive and fast L1 cache(128KB, 64KB data, 64KB instruction) and L2 cache can be as big as it can if you can get good yield and if price doesn't bother you. The consequences is slower L2, but the L2 latency can be masked with a victim buffer between L1 and L2 caches. Memtest doesn't see the victim buffer and therefore gives a wrong impression of the overall system performance.
If you want a good benchmark for system memory, there is nothing that rivals Sisoft Sandra as it uses at least 128MB-512MB depending on your system memory.
Don't be carried away with those numbers you see on memtest if you can back it up with real world performance.
As for my observation. I used Intel and AMD systems (Intel for mobile and AMD for workstation). Some people like the megaHURTZ from Intel P4's but that's fine. As for me I will not get stuck with a brand name except if I work for them, or they pay me some money to do so.
great job.
I know exactly what you meen............Don't worry........I just wanted to see an unbuffered compared to the BH-6/5 chips......... ;)Quote:
i thought fugger meant the L1 and L2 bandwidth, it is massive
Fugger, Excellent result there w/ DDR2 and fast timings. :toast:
What sort of unbuffered Sandra mem bench can you get w/ those settings?
'the stilt' has been testing the ocz DDR2 too and he managed to hit some nice speeds too (w/ asus mobo):
sandra unbuf @ DDR716 3-2-2
(268fsb and 3:4 divider), I'm guessing that the lowish FSB is holding it back a bit and running 1:1 at those speeeds would give even better result.
Working my way up to 4.75k unbuff
I have a 4.55k posted in the "first look" thread. I been holding back on the unstable stuff. But I will post a little something special just for you macci.
Gimme a few minutes to fire up the hard drive.
4.75k unbuffered, thats good, so at what fsb is that at, still 3-2-2 or?
The 4.5K was done at 333FSB 1:1 3-2-2-8
But the attached file is better, you can see my desktop junk too. I usually cut it out to save bandwidth and screen space.
Really now, you think Far Cry or whatever your game of choice may be is any more enjoyable at 100fps instead of 90fps, please, but I can tell you that multi-tasking is more enjoyable with HT :)
great job as usual, congrats FUGGER
Cleaned up and booted him from this section. Unreal
