Is this new revision suppose to fix the mem controller?
if these chips are using 754 :D :D
They are using 754, which is why I'm saying if a Revision E for 90nm is coming out for 754 then there has to be one for 939. BUT: With turion launching in April, then what I have said time and time again the Revsion E for 939 won't come out until summer, is now true!
OR!!! it rev e 939 might come out b4 the 754 to test yeilds, in order to hand pick low wattage ones for mobile stock.
jesus this thread is turning into a rumour pumping machine!
think about it tho it makes sense. All of their mobiles so far are just handpicked desktop chips with no ihsQuote:
Originally Posted by DevilsRejection
Has it been confirmed that E0 chips will use strained silicon?
they probably are, how else are they acheiving such low thermal ratings
Any word on cost?
http://www.digitimes.com/systems/a20050205A2003.html
Although AMD has set the prices of its Turion 64 CPUs about 13% cheaper, on average, than Intel’s Pentium M (Dothan) processors, some vendors have suggested that AMD needs to aggressively lower Turion 64 CPU prices to around 25% lower than P4 M CPUs, in order to gain market share from Intel, the sources said.
So these new chips are 1mb cache, (probably) strained silicone, 25w, AND socket 754?
I just may have to pick one up for my DFI nf3 board when they come out then :toast:
The first article says ~13% cheaper than the P-M Dothans. Considering the Dothans range from $215 to $645, maybe $187 to $561 for the Lancasters? Even though I couldn't imagine a mobile CPU being that much.
lets hope that these come out for the s754 and give hope to us people who cant afford 939, AND o/c as well as the mobile XP's, but ill try not to get my hopes up :D
if those specs are rite, it must be socket 754,
3200+ with 2ghz and 1mb cache vs winnie 2ghz 512KB cache and so on
then 3700+ should be 3500+ 2.2Ghz w 1MB cache ?
they will be on 754 first, im sure those 90nm 1mb chips will come to socket 939 pretty fast as well though :)
think they will have dual channel mem controllers on there?Quote:
Originally Posted by saaya
no, the socket 754 line doesnt support dual channel. its not that they disabled it on the cpu's.
http://www.xbitlabs.com/images/news/...e_rdmp_big.jpgQuote:
Originally Posted by pik-ard v1.1
from what i've seen in the reviews of the Dothan, once its pumped to 2.6ish it goes toe to toe with the FX-55 (2.6). the AMD still give better performance per cycle than the Dothan dose with less L2. I dont see that changing for any of AMD's cpu's. just my observation though.The Dothan would have kicked ass if it would have come out a year sooner.Quote:
Originally Posted by Poki
Why dosent AMD give us a FX with 1meg L1/2 meg L2?? now that would ROCK!!
bri
Its as frosted flakes says - it is the umbrella name for all in that category - it is most definitely not a E0 Winchester (cough cough venice)! There is more to an E0 than just SSE3 - e.g. an extra 2 layers (9 to 11). ALL A64s under manufacture will move to revision E in time including Semprons but that does not make them Winchesters!
L1 doesnt matter much, 128kb is fine as its only used for low level stuff, not a lot of data goes through it. i belieive
but i get what you mean :thumbsup:
754 is getting very good, the ony good a64 motherboards with agp, now have 90nm 1mbs!!! AND they are mobile :D :toast:
:YIPPIE:
droool.. i want one
Calling Turion "Winchester Rev. E" would be like calling Winchester "Newcastle Rev. D". ;)
OT:
Maxx, same bday. :cool:
All the fx chips have 1meg L2Quote:
Originally Posted by brian770
