(the post i was responding to seams to have disapeared)
its easier to distinguis and the server doesnt allow that many pic in one post ;)
wowsers nice :)
sticky
that is the best post of evaps i have seen. :toast:
those first few evaps are soo good, i wish cnc maching wasnt so expensive.
here is my first one
I agree with a sticky :toast:
Question. What's the difference between those blocks other than their interior? Are those designs specifically made to optimize cooling?
i want the pics to be stored in xs disks. Not in another server.Quote:
Originally Posted by alexio
Plus i can only upload 5pics per post.
You've got my vote for a sticky! :up:
These are gorgeous, keep em comin :D
SWEET!!!! :slobber: :slobber: :slobber: Great thread!Quote:
Originally Posted by cold_ice
how it works???Quote:
Originally Posted by gclg2000
goes from the bottom up, if you notice the disks arent 100% aligned. That is so the refrigerant can flow through.
Originally Posted by JSU
thx, understand :)
Hawainpandas block no.1
^ not too shabby, just that thin wall scares me...
As long as you don't torch through the wall its fine. When i brazed it shut, it never got even close to burning up...The metal is lieterally touching the insde chambers (within a few thousands of an inch), so the heat just spreads and spreads throughout the whole block. It can withstand plenty of pressure too :banana:
:toast:
Click here and you can see the cap tube inside the tube.
Well the walls of copper pipes are only 0.032 thick or something, so I'd imagein it would be fine, but it would be better in copper either way (i think thats brass isint it?).
yes i think its brass
maybe HP can enlighten us?
but chilly1 has tried brass and said that at the temps of DD/ cascade the difference between copper/brass is crap all
Nice, looks like you brazed it rock solid.
i think that would work very well :thumbsup:
yea that looks good, i like the design. the suction goes to the side opposide the cut in the large channels, right?
Here is a cpu and a gpu/NB evap iv made,ill try to find better pic's of the finished bGPU/NB block.
http://www.snt-systems.com/tommy/evap1.jpg http://www.snt-systems.com/tommy/evap2.jpg http://www.snt-systems.com/tommy/evap56.jpg http://www.snt-systems.com/tommy/evap57.jpg
Originally Posted by Aphex_Tom_9
I don't know for sure what u mean but I think yes :D when you look at the first pic suction is in the middle of the upper channel.
Unknown_road's first photo makes me.. grotesque feelings
Very nice braze, you didn't save of braze rods :)
Are you using propane torch?
