Originally Posted by Radical_53
Well, we had high-flow blocks here too. Thing is, that was about 5 years ago. Also, have you ever heard of the Laing/Delphi DDC pump? It's small, silent, has an impressive power and needs only ~10w to operate.
High flow might only have an effect on the efficiency of the block, but not the rad. Also, chipset/graphics blocks aren't that restrictive, as they don't have to cool as much (normally).
We also have tests here with all kinds of pumps, without flow restrictions and e.g. with 10mm tubing. Flow suffers dramatically when using 4 or 6mm ID tubing, but anything above won't harm flow that much. Also, a certain flow is needed for good performance. Anything further would only improve performance by a very small margin, nothing that you or me could really measure.
