Originally Posted by reject
Hey man are you using lightstep if so how do you like it?
Dragon
Dragon
Also what about flashing to an Ultra bios if you card can do those speeds i have heard that if it can that it can also ne you a little better clocks and some better performance...
Dragon
Can someone make a thread like this for 6800 Ultras? :D
i know this has nothing to do with the 6600gt, but i also have an old fx5600 and i waz wondering if the software could be uzed to modd my fx5600 bios?
my PC'z
pc 1
3000+ @ 2.2ghz (70 x 8)
duel channel 1.5 gb of hyniz ram running @ 440mhz (2x 512 ans 2 x 256)
SATA 2x 200gb hdd (400gb )
asus a8v delux rev2
x800pro @ 550 / 520
sound blaster live 5.1
500w psu
big water (water cooler)
pc 2
p4 2.8 ghz @ 3.6ghz
asus p4p800 delux
1g duel channel ram @ stock speed (400mhz)
6600GT 128mb
40gb
350w PSU
pc 3
(used as a HDD server)
semperon 2400 @ 2ghz
fx5600 (leadtek a310)
768mb ram ddr 400
120gb hdd + 5gb hdd ...LOL
350w psu
pc 3
1.6ghz p4 @ 2ghz
msi mainboard
512mb mem ddr400
r9200se 300/200
40gb hdd
350w psu
uh...thats 1024mb (1gb) of ram :rolleyes:Quote:
Originally Posted by x800pro6
Originally Posted by echow87
sry no
2x 512 and 2x 256
Guys,
I'm running in 420/1140 rock stable with a nice performance!! But as I am doing the first day of tests in the card, I wanna know if there is any problem to run it on 1.3 volts (default).
In my ex-MSI 6800GT I had edited the BIOS, and set the voltage from 1.3 to 1.4 volts in both 2D & 3D.
Now the Leadtek is doing fine with these clocks, but I imagine that it's running with 1.3v. Is there any problem with that? If I should keep the clocks, it's better to edit the BIOS and set to 1.4v?
Thanks a lot!
AleX
Hey, i know this is old thread, but it beats making a new one :-)
I just tried edited the bios, upped the voltage to 1.4 but it hasnt made a difference in my OC. I could get 446:1250 max before and its still the same now. Is there any way of testing if its worked without a multimeter?
(BTW its watercooled)
How do i enable "Force constant performance level" option. It says disabled in the box and it is gray, i can not change it !
another little idea that can help people.
Download Gainwards "Expertool" program from that thing the "internet" and then you can manually set the fan speed of the card to 100%. Coupled with arctic silver 5, that will drop temps a bit. at 1.4v, the core will start getting WAY too hot past a point, but better than nothing.
I also want to know how you put the Thermalright on the GPU with zipties. I am guessing you removed the RAMsinks to do this?
thanks for your tips HaLDoL. Setting 81 mhz agp frequency helped remove artifacts. The sweet spot for my agp voltage was 1.65 volts though 1.8v seemed a little overkill and brought back the artifacts that raising to 1.65 got rid of.
IS this the same as agp VDDQ voltage?Quote:
Set AGP voltage to 1.8V at least
[edit]
Yes it is :) but i think 1.8 is a bit overkill, i have set it at 1.6
[/edit]
hi ya.
wow what a cool thread !
I'll try O'c this mother and see what happens.
I've beemn playing around myself. but not done any volt/BIOS mods yet.
here's my best score
http://service.futuremark.com/compare?2k1=8868012
28200 ishh ....
I've reently changed ram .. and thus HAD to change to a modded BIOS for my mobo. .... as yet it's not stable enough ... and my scores have gone out the window. :mad:
I'll try the mods and let you know. !
hey HaLDoL, you got any pics of the 478 HSF on the card ..??!?!?!?! :)
It would make me smile AND give me an idea how to do it on my gainward.
P.s i brought a Zalman FS-V7 Fatal1ty VGA Cooler, and at BEST i broke even !
Can I ask how many people have really seen cards die with 1.4v? Because I been running an le now with 1.5v for a couple off months and no problem at all besides the burning plastic smell if I forget to put a fan on the pcb ;)
Pc is running 10h a day atleast, 2d clocks flashed to 400-800 and 3d clocks set with rt to 450-900 most off the time, highest I benched with till now is 460/950 but ever since I went from stock cooler to a zalman v700cu my ram craps out above 920. Those tiny zalman hs's aren't near as good as I hoped even with an extra 80mm fan blowing over them and the pcb :(
i didn't know that the cards can die on 1.4volts.
I had planned to do this mod in the next 2 - 3 weeks.
the zalman fan is not very good for me. and i don't know which cards ( if any ) they make a real differeance over the stanard cooling.
1.4v on a gt would be less concerning then 1.4v on a le, diffrent circuitry iirc. I got a Zalman v700cu which didn't help oc much but is colder and more silent then the stock cooling.
I think I've squeezed the last drop of my GT before moving on to vmod & water
http://service.futuremark.com/compare?3dm05=1922744
P4P800SE unmodded semi-pat enabled
P4 3.2C SL6WG 12 CAP Costa Rica @ 3.91 1.6V cooled by Big-Typhoon
Mushkin XP4400 488mhz 2.5-3-3-5 2.85V
Leadtek 6800GT unmodded + Thermaltake Thunderblade 120mm 12V @ 450/1230 1.4V BIOS mod
AGP/PCI @ 74.67/37.33
OC'z Modstream 520W
84.21 WHQL drivers
LOD 3+
Any last minute's advice?
lol. Reviving this old thread I know, but with my new rig almost complete, I had to just try ragging more clocks out of my... WAIT FOR IT... 6800 LE!!! :doh:
:horse:
But still, I got 405mhz clock and 823mhz memory out of it. I've already unlocked the active / vertex pistols to 16pp/6vp. It's unlocked to a GT bar the ram differences of course!
It'll go to 415 / 835 in Rivatuner, but I'm not risking that as my mom is having this system after me! :p:
this may be Ot, i havent even read the thread yet but yu kno what?
you know how you know it wass a good idea to explore a new section of hte forum?
first thread i see is supn im in of dire need. i have 2 68 gts and wanan learn how to OC them since me and my computer have been twiddling our thumbs bored as heck nothign to do (since my config aint changed in a while). so maybe this will give me some extended life to the setup in the meantime. or else ima start cleaning my waterblocks again!
i have an agp BFG 6800gs with a zalman heatpipe cooler, the card is pretty good and stays cool (48C at idle/62C at load) it has suited me well, but i want to push some more out of it.
i have rivatuner and have un-locked the pixelpiplines and vertex to 16pp/6vp
from 12pp/5vp, there is a definte increase in my score when i run 3dmarks01 or 03
however when i overclock the memory and core i get worse results in 3dmarks tests, with the pp unlocked. i figured it was better not to overclock it and just have it at stock speeds and have the pp and vp unlocked.
so i kept it at that, but reading this thread got me thinking.
should i adjust the agp voltage and agp speed mhz in the bios???, maybe that will help me be able to OC the core and memory. im not sure how much to increase it by though becuase ive never done it.
at stock the bois says 66mhz and the voltage is at 1.5V
i have a asus K8N mobo, it has the nforce3 250 chipset
also what is aperture size? mine is set at 128mb.... it can go up to 256 and 512mb?
any body else have this card?
I ran stock cooling with 1.5V on a 6800nu for 2-3 years before it died :) Ran 450core no problem too.
BTW this thread really needs to be unstickied.
So bottom line, will an overclocked 8600 GT run on par with an 8600 GTS? :confused:
guys sorry to put this up..I have an Albatron 6800gt and a powerstream 420w,do that mod #3 worth in my case? I have the card connected to that black molex that the psu have for hdds and vgas..
about mod #4 81mhz is specific for 800gt or for nf3 dfi board?I guess it is more mboard related...
Would my soundcards run @81mhz agp?
Why is this sticky still around??
