funny stuff someone had similar problems but messing around with AGP Aperture size fixed it... not sure if it will help but try it out :)
Hey man, thanks! :toast: Are both of those points used for the Vcore together or seperate?Quote:
Originally Posted by pc ice
I like your on/off for the vmod:D
Ha ha! I've been looking for those! Thanks for posting those pc ice. Now I just gotta get mine installed. :toast:Quote:
lol. if you don't, I will. I mentioned as much in that section cause I did find the mod info, except for your addition, but the info is spread out everywhere. A nice consolidated thread would be a good thing for others.Quote:
Patience C3, it's coming. If it isn't done by the time I get mod'ed I'll do it. This weekend at the latest. Even though I have 100% confidence in the stuff I found, if I post it I want to be sure it works so I gotta do it first. :)
Could you send it to me, please
orlandojdr@ojdr2001.com
Can host it if you want
yfriedsam@hardwareluxx.de would be great!
I'll host the pic for you ICE, just send it to me. I can give you some space to put the whole mod guide up, I've got tons of space :D
virtual.octane [at] gmail.com
Got it :) !THX very much!
someone can compare X800XTPE 520/560 and X850XTPE 520/560 with same cpu and ram settings under 3Dmark2K1 ?
pc ice, got the pic, thanks
Here it is the link: X850XTPE MODS by pc ice
this VC sucks : 28750pts with stock settings (520/540 optimal perf) and FX55 stock just A64 tweaked with BH5. :/
..Or my K8NXP-SLI hate it.
29100 high perf. it's so bad !!!
I ve tried to flash with 850PE bios : not better
I ve tried to flash with 800XT bios : lots of ram artefacts at 540 and no score improvement :confused:
@ misteroadster:
Might be the mobo or something with your config. I'm at lunch, so not much time to play, but you got me curious. System just set up so mem at 2-2-2-5, no other tweaks to mem, no P&R tweak, no cpu or PCI-e sideband, pretty plain run. Using XP and 520/540 and 2x256 BH5 I just got 30001 with default XT850XT-PE bios and Cat 5.1. I gotta go back to work, but I will be testing XP/2K, more tweaks, o/c'ed, etc over the weekend. I can try some more stuff for you if you want. The WinXP 30k seems on par with what I'd expect. I had a Neo2/X800XT-PE stock clock W2k score to compare and did like 31K, no P&R tweak, that 1k difference is from W2k and A64 mem tweaks IMO.
edit to add: Done on a DFI Ultra-D with whatever NF4 drivers where on the CD.
thanks mikead , your results are better than mine , but i think the m/b is not the only problem , there is a problem with X850 too i'm sure.
I think i have to jump in the DFI train now, and wait for better drivers for this thing.
my system in sig I get 13k stock in 03...
btw, is there a command to use DX8 when U got 9c installed to run 01 ?
It would suck me having to uninstall my 9c DX to DX8 to run 3dmark01 then the reserve to get back to 9c
Strange thing i haven't improvement with 2K+Dx 8.1 , so you can bench 3Dm2001 with Dx9c i think, just patch it with 330 patch.
Strange 2001 ranking :
OPB(DFI) and Pinto(MSI) sucks a lot but Jason(DFI)result is good with a winnie.
Herms(DFI) result is not so bad but not great.
http://pageperso.aol.fr/misteroadste...llX8502001.JPG
Hmm, I wanted to try a W2k run with 520/540 too, just to see how it acts in my setup. I can't get anything to work to adjust the clocks in 2k either. I'll keep digging around, it's obvious by some of the scores in the rankings that something works with this card in W2k.Quote:
Originally Posted by misteroadster
yes , try powerstrip , it works ;)Quote:
Originally Posted by mikead_99
update with dfi-sli
http://img88.exs.cx/img88/7579/3Dmark01374531.jpg
Thanks! I'll do that. :toast:Quote:
Just another minor update, I do see a bit of a boost with W2k still. I ran all services, except Explorer, just had to close it, and real time on both OS's. Still Cat 5.1's, mem tweaked a bit with Tweaker, same mem tweaks each OS, and default cpu/gpu clocks. Got 30865 in XP, 31217 in W2k. It's not the boost I'm used to seeing, but it's enough to know W2k still gives some love for me. Car low's were run until a got a good one in each OS, so that isn't the difference.
Poor score my friend for 3171mhz FX :(Quote:
Originally Posted by pinto
2000 points are missing , even 800/700 card cannot give them.
Well, it looks like I am missing a few points. Nowhere near 2000 though. That all stock compare I used from my MSI NF3 gives about 300 points more then I got in W2k with this setup with 520/540. This setup beat the old in some tests, but DL and Nature got hit. Something about the MSI, it smacked my 9nda3+ in DL's too, same VC in both boards. I still haven't tweaked the bios in this board at all. I'm booked until later tonight, but I'll see if I can't make that 300 up in bios.
edit to add: Nature took a beating by about 9 frames, makes me wonder if mem timings on these boards aren't relaxed a bunch to get those extra clocks. Same part on both boards, suddenly they clock that much better?
here's a compare FX/winnie under WinXP non acpi tweaked , the 1100 Pts difference is abnormal , it should be 2500-3000 pts , the problem is the motherboard (Bios) for sure , i think the winnie's score is good.
http://pageperso.aol.fr/misteroadster/AwfullX850.JPG
http://pageperso.aol.fr/misteroadster/x850xtwinnie.JPG
