i have thought of that problem, thats why i bought SLI D, so at least i can use 8x if not 16xQuote:
Originally Posted by HARDCORECLOCKER
zern block? you mean this??
:D Ohh - didn't see that it is the SLI, now I see You go 8x.Quote:
Originally Posted by nigelyuen
I asked 1 A to give me the hight of this here, the left one:
PIC
And it's 26,5mm - please can You measure the space between PCB and edge of GPU, maybe this one fits - looking good with the tube connectors sideways.
:toast:
i have found the best solution now
1a cooling block doesnt really fit
iam using the alphacool nb block, but its only G1/8
:D Hey, nice work man - maybe You're the first with watercooled chipset on that board !!!Quote:
BTW, what about the 26,5mm ? Can You measure it, would be interesting if the ZERN will fit......., hope You did see the pic. THX !!!
:toast:
that zern block isnt gonna fit
my zern is 2cm thick, my alphacool block is a lot thinner than that, and there is 3mm clearance between the block and vga card
:D THX for help - so I can burry this idea............. :(Quote:
:toast:
Is that a 6600 card? The alphacool dosent fit with my Inno3d 6800GT - theres a capacitor in the way of the barbs. I think i can make a new mount i might get enough of the block over the nb chip to be effective, and clear the cap!Quote:
its x850xtQuote:
Originally Posted by stu_allen
Ah, i see.
After playing about this afternoon i dont think this block will work on a 6800 setup. :(
good aircooling is probably sufficient for the nB
Yea thats what i thought. Who the hell in their right mind would use something that restricts flow that badly?Quote:
Originally Posted by Karnivore
Except that with 2 pcie gpus in place, it dont get much air. And its noisy (my main reason for wanting to replace it)Quote:
Originally Posted by charlie
No i cant! The base of the alphacool isnt flat, the contact patch only starts about 4mm in, so it wont make good connection.Quote:
Details here: http://www.bleedinedge.com/forum/sho...7060#post67060
I would.Quote:
Originally Posted by Sentential
when benchmarking, I want every single thing cooled to the absolute best I can cool it, especially when using dry ice.
I have about 5 waterblocks sitting around, that get only occassional use, I have about 6 pelts that get almost no use, except rare occassions.
I have a spare pump... and when I need, I will just get another cheap radiator for one waterblock alone, and use 2 seperate watercooling systems.
when it comes to benchmarking, especially when messing with dry ice, and volt mods, I use every possible cooling solution I can, even north and south bridge cooling...
to me, it's no more pointless then say.... ram sinks on mosfets.
who would use it? I would.
:D Normally there should be no cooling problem when living in ALASKA... :p:Quote:
Originally Posted by Kunaak
:toast:
LOL...thats not what I meant at all. I wholly agree with that Im purely refering to JUST that block.Quote:
Who would use THAT kind of block. Cooling is one thing but seriously there has got to be a better chipset block, one that doesnt bring your flow to a standstill.
btw i sink my fets too lol :D
Here's mine
1/2" inlet and outlet, 2 x parallel 10 mm bore channels connected by 2 x 7.5 mm bore channels. Minimal flow resistance :)
BTW I'm rather better at metal work than I am at photography ;)
http://img200.exs.cx/img200/4618/dfiblock22gn.jpg
http://img200.exs.cx/img200/8431/nf4block11rh.jpg
http://img200.exs.cx/img200/1159/dfiwatercooling9yf.jpg
that block looks good.. check your pm's
Cool!:DQuote:
Originally Posted by uranium
Self-Made? :toast:
Nice work Uranium. Fancy making me one? ;)
Yes :)Quote:
Originally Posted by Juspriss
I'd love to make you guys some, but TBH I did this at work (Uni) when other people weren't using the equipment so its not that realistic to go into mass production. Sorry.
Happy to send anybody a drawing though :)
whats the file type? DXF? DWG? i would love to take a look at it.
Hi :)Quote:
Originally Posted by MaxxxRacer
Actually its free hand pencil ;) But I will do a proper one, covert it to pdf and e-mail it to you if you let me know your e-mail address
OK doing it now on CAD program. Can do DFX file type if you like
Cheers
Geoff :)
Nice, I'll send you a PM if you can also mail it to me :) Nice work, uranium!
