I have Chilly 1's dual stage Cascade. :toast:Quote:
Originally Posted by HARDCORECLOCKER
Chipset? do nothing..just original fan on it.. :D
see the NB fan there?:D
http://coolaler.nil.com.tw/images/hifsb/HIFSB4.gif
:D @Onepagebook:
Yep - dual cascade cannot be compared with a sigle phase - if I send You my CPU it would run 3,6GHZ with Your cascade..........
But 400 HTT chipset on air is outstanding for a NEO2 - never saw this....!!!
:toast:
Did you see above?
well, I remeber I get 1.85v for 3.4xg on Vapochill LS too..;)
forgot where I put that 3.4g pic, but here is the 1.8v on vapo LS run after 3d01
:D
http://www.e04hardware.com/fx55/39534.jpg
Congrats!
Absolutely wild speed!
Seems I now got serious competition. (Except for the cascades, of course, especially 1pgb who obviously has unlimited resorces ;)) But still a cascade won't run 24/7, or am I wrong?
I was chasing 24sec. today, but no go... It's pretty close, though.
How about your 8M?
BTW, we actually tested a friend's FX-55 on my rig today and it would not go ower 3.05GHz. Any memory, any settings. A really sour apple. 0432MPMW. Beware of those! :D
EDIT: typo, might be a lot more :mad:
:D Now with a little more Vcore improvement of speed & bandwith - this is almost unbelievable on single phase - seems to be a real killer board and CPU is an animal: :slobber: :slobber: :slobber:
http://de.geocities.com/hardcoreclocker/10x348.JPG
:toast:
Hey OPB, isn't it dangerous to make the AGP clock above 66?
:D Here're some PICs for You all - You only can believe what You can see...
http://de.geocities.com/hardcoreclocker/A64Sys001.jpg
http://de.geocities.com/hardcoreclocker/A64Sys002.jpg
http://de.geocities.com/hardcoreclocker/A64Sys003.jpg
http://de.geocities.com/hardcoreclocker/A64Sys004.jpg
http://de.geocities.com/hardcoreclocker/A64Sys005.jpg
:toast:
Wow, nice! I still want my FX-55 to take 3.2GHz in Windows reliably with my Vapo LS... 3.05 or so is not very good. I wonder if I've applied the clamshell wrong somehow? :stick:
can I get 3dmark 2k3 or 2k1 at 3480mhz ;)
Heard for some reason that it helps when clocking to extreme htt to keep agp in synch, surely though your vid cards gonna die doing that though.....Quote:
Originally Posted by shadowing
Great clocks guys..Quote:
Originally Posted by Onepagebook
Isnt your cascade still at reggies opb? I just spoke with him two days ago..
I second that...Quote:
Originally Posted by choseone214
Nice cpu you got there :)
My FX55 does 3514 Mhz with a R404a Mach1 but only for screen
3400 for 3Dmark and 3360 for Spi
My Neo2 did 355MHz stock cooled with 3x LDT, nice board you got there OPB. :slobber:
http://home.no.net/comerade/pc/355htt-neo2.png
Kam> nice stuff I likes ;) rock that HT bus speed
:D @Kamerat :
Nice HTT dude - but 177 mem frequency seems a bit low - what's Your RAM ?
:toast:
Thanks :toast:, running Corsair XMS3500 2x256MB (BH-5), but didn't try to max it when I was testing for highest HTT. It's doing 272MHz with 3,9V and 2-2-2-6 timings. The Super PI in my sig was done by using this RAM.Quote:
:D @Kamerat:
Yep - You use the 100 divider but try 133 - that results in a mem speed of 236 which is quite easy to to for BH-5.
MUST bring an improvement of performance to You.
If You are able to try other RAM with TCCD You can use the 166 divider - results in a mem speed of 295 which are most TCCD doing with 3-4-4-8 or if You get a good pair of them even with 2,5-3-3-5.
:toast:
The most optimal setting must be the "166" divider and a mp of 9,5x, that will give a RAM divider of 12 and let me run the RAM at the same speed that I'm running now. If the Neo2 had the "150" divider I could have used a mp of 9x or 8,5x and get a divider of 12 on the RAM.
:D Yep - You'll have to go for DFI NF4 - contains all the nice dividers we are looking for.............Quote:
Originally Posted by Kamerat
:toast:
hardcore whats you batch number on your week 0442 chip??
J40050 for exapmle?
:confused: Hey dude - not easy to answer - did't notice it before mounting my prommy on it............ :dammit:Quote:
I'll take a look at my receipt - in a few hours - I'm still at work, hope it shows the batch number.
:toast:
:D Didn't find it on the receipt but on the box, its K40112.Quote:
:toast:
