Bigtoe,
I'm working on A64 tweaker and 3700EB if you know some good settings could you pm me?
I should have some results with a Gigabyte K8NF-9 NF4 board in the near future, hopefully my booster works in it. :D
Bigtoe,
update - im currently *Stable* (windows, i havent memtested yet) at 285 3-3-2-8 on 1 stick of 512mb
im going for 290+ 2nite
With how many voltages on your memory?
Thanks,
SliNGky
What I have is not OCZ EB but my Buffalo 3700 uses Micron -5C. I can do 267 3,3,2,5, T1 with 3.3 volts but I leave it at 250 2.5,2,2,5, T1. Its a single 512 stick and the mobo is the bottle neck with a max HTT of 267. I beleave it will do more with a mobo with higher HTT at 3.3 volts.
2x512 3500EB 280mhz 3-2-2-10 @ 3.4v on an50r and dfi nf3.
i think my C0 is limiting me.
i adjusted my Powerstreams 3.3v rails to around 3.6 and am using the vdimm bios for my DFI UT so i was around 3.38 as Klisp said not to go to 3.4 if not using a fan (which im not) - when i use a fan tho im going for 3.4 and 265mhz :DQuote:
Originally Posted by SliNGky
I was trying out some stuff with ClockGen today (school is cancelled because of freezing rain), and I got a screenshot of my PC3500 EB doing 250MHz 3-3-2-8 @ 3.3V. I still think my mobo is holding me back, but it's not bad for nForce2.
nice work :D
My EB seems to love the tightest settings I throw at it as long as i use cas3. At 290 i was running 3-2-2-0 with TRC at 7 and TRFC at 14 with bypass max at 7 for some huge bandwidth ;)
coudl you post or pm me how to optimise my memory settings for when i get my 3400NC?
as i really have no clue
cheers
I did a little more messing around with different BIOSes and raising chipset voltage to 2.0v and finally got 254MHz, 3-2-3-8 with 3.3V.
None of this is stable because of this motherboard, though. :( I shudder to think what this stuff could do on an Athlon 64 system. :banana:
hi, thats my fist post here at xs.org :)
i'm getting some 3200EB on Saturday, and i hope i can post some huge results. I already had some 3200Eb earlier, and they reached 244/2.5-2-2-5/2.9V -- limited by my mobo :(
This ones now, made 265 by my friend, but dont know what timings. I'll test and post.
btw: great Forum here, hope you understand my English.
Hope it goes well :D
but cant you get some 3700EB or VX for that same money?
that is if your paying full rate :D
YES!!!
these babies are fully stable at 250@2.5-2-2-6 :D :D :D
im running 250x9 - im happy now
3.36v
:banana: Booster is here :) We'll see how it does with some 3.3v action :D
:toast: to both of you. :)
hey bigtoe can you post a screenie of you A64 tweaker at that mem speed?Quote:
Originally Posted by bigtoe
just curious cause i can get 280 3-2-2-10 stable but any looser timing it craps out.
i just want to see you other timings at 290mhz plus is it 2x512mb or 2x256mb?
Well with he booster and only 1stick of EB it does around 270mhz with 3.3vdimm.
This was on a 10x multi 3200+ winnie, i'll lower multi and go at it again.
BTW, booster works on K8NF-9, i tried 3.9vimm but dunno if thats what I was actually getting or not.
no Korpse, because i'm only paying 210€ for GB-Kit.
btw: i got them yesterday, and one stick doesn't work :( , fu** i hope i'll get another GB-Kit of them from RMA.
didn't test the other one yesterday, because i've been terrible angry.
unlucky mate
