Great scores mate. Keep up the good work.
Tks:)Now I'm waiting for the Vitesta and the DFI UT lan for try to broke my records :) For now a little up on the 3d'05...6347Quote:
Originally Posted by Klisp
http://service.futuremark.com/compare?3dm05=469146
Cool.. i get 31,504 on my dfi UT lan. So u should get a higher score.
Good scores m8 :) I'm hoping for similar results with my setup, once my 3700+ comes back from RMA. I have a DFI nF3 LP waiting for it, which I haven't tried before :cool: hope I can clock it good.
Keep on running! :toast:
--------------------------------------------------------------------------------Quote:
I have some problem with my DFI UT...the first is if I unable the Cpu thermal throttling from bios the PC don't start why?It's normal?
The only way it's reset the bios...another thing...it's normal that from bios I can't overvolt cpu over 1,55volts?The "Cpu VID special control" function...how work?I have see that it's possible to set from 104%to 136%...it's for overvolt cpu?
sorry for bad english
For cpu thermal throttling to be disabled you need to download the 10/05 bios. just google it.Quote:
Originally Posted by nachthymnen
For the cpu voltage... set it to 1.400 x 123%= 1.722Vcore Try it on a calculator. :)
whats reserator???Quote:
Originally Posted by Kanavit
Tks:)It's the first time I try a DFI MoBo...yesterday I have try a super pi 1mbQuote:
with 270x10 but only 33seconds :( Same like 225x12...it's normal?
I have take also the 280x9 but no good results :(
http://img87.exs.cx/img87/5853/OC.jpg
fsb doesnt matter. memory speed with reasonable timings matters a little, but cpu speed is most important
Congrads on your score man.. now on to the next objective..ehehe
Nice man.
Almost identical PC and scores to me. Though i ran at 10x255.
Dam timmings are well important on 01.
My cpu it's not very lucky...@2740mhz don't close the Spi 1MB :(In 3d'01 i'm stable until 2680 mhz :(
Be sure to tweak all those extra timings for the memory.. they will gain you some marks..
And finally I have take the 32" on Spi 1MB:)
http://img162.exs.cx/img162/3364/Superpi32.jpg
A little UP also in the 3dmark'05:)
Cpu@250x10 and vga@547/594
http://img231.exs.cx/img231/9843/3d05r7tj.th.jpg
we made 30k with stok x800xt ... :D
A64 754 3400+@2800mhz
http://service.futuremark.com/compare?2k1=8187935
2k1 is only cpu:)Quote:
Originally Posted by Brandybuck
Correct but it does use some GPU.Quote:
A bit in dracothic and nature...wright?Quote:
Well, about abit i just about all of them but the most in nature.Quote:
LO. Thought i recognised that number.Quote:
http://service.futuremark.com/compare?2k1=8370037
Yeah!!!The same score :D I have take the 30.5 k but I have only a photo of my monitor :D ...on super pi I have take the 32"but the system was really unstable :(Quote:
Originally Posted by Grov
wow nice work man, some nice clocking on that clawhammer :toast: :toast:
