how much? 1.5? I cant go higher in the bios than 1.5
sry my bad english
i can not flash that because it says something about ID :(
can you use savebios? here it is. Unzip it and double click. It should give you a copy of your bios on your vid card.
ok here...
http://www.oc-rapid.com/6600GT/VIDBIOS.BIN
I dont know why, but I cant understand what the hexworkshop is saying. I cant find where to make the changes. Most of the other 6600GT bioses are easier to find them. It might take me a little time.
1.5V, i dunno if its safe on the stock cooling, 45C idle?
I didnt check, the highest it says the card can do is 1.4v through the bios. that means you'll need a hard mod to go above. Here is the bios. Clocks are 500/1000. Volts are 1.4. It should be OK at 1.4 on stock cooling. Just for your info, it was originally 1.3V.
i think its safe... how you rise voltage?Quote:
Originally Posted by MaRtIe
i havnt raised voltage, it was a question
Originally Posted by moddolicous
whos is that bios?
I got that bios off of mkvtech.net. It was under XFX 6600GT bios. I downloaded it and modded it for you. It should work.Quote:
thanks :toast:
report back if you had good results
will do, just pluging my floppy in now and gathering the flash tools
floppy drive doesnt work, (anceint) any other way a video bios can be flashed?
you can try doing through windows, but I'm not sure it will work..
1 click run and type cmd
2 put the utility and the bios and anything else you need in the documents and settings folder
3 use the same commands and it should flash. Not sure
Good luck
cant get it to work,
how about a boot cd?
that will work.. Forgot about that.
so all id do is put the files that would be on the floppy on the cd instead?
yea, but you have to be able to make it bootable. I'm not sure how to though
If you look for BIOS's then check mvktech.net... And also try to upload or to mail me your Original BIOS.
If you want to mod a BIOS yourself then use NiBiTor (it is available on mvktech.net).
Is the XFX 6600GT bios on that site for the AGP version?Quote:
Originally Posted by Mavke
If not, anyone know of a modded bios that will work with the AGP version of XFX 6600GT?
Edit: Nevermind, i found out via the forums. It might be a good idea to specify at the download pages though.
Does this XFX bios on there have upped vgpu?
All BIOS's on my site are the Original Versions. If you need to up the voltage then use NiBiTor (also on our site, and developed by someone I know and beta tested by myself).Quote:
Originally Posted by q149
And also I would like to get as much 6600/6600GT BIOS's so if some do have such a card please send me the BIOS!
mavke@mvktech.net
i have my original XFX 6600GT AGP8 bios. ile mail it you :)
Thanks! I look forward to receiving it... :-)
