Oh that's nice! I think the 1024 MB Modules are holding me back!! :rolleyes:
Finally testing system: 4,5Ghz but 4,4Ghz rock stable...
Can't pass 700Mhz with the Corsair at this time, 4-4-4-12 and 2.0v...
I've been testing and now I can achieve 315x14,
With the Corsair 3:4 840Mhz at 4-4-4-12-4 with 2,1v,
This is rock stable but I think I can go a little higher...
I'm using these voltages:
Chipset Core Voltage: 1,75v
CPU Vcore Voltage: 1,5000v
FSB Termination Voltage: 1,45v
Do you think it's too much for 24/7 ???
I'm going on testing...
I can show some screenshots of my actual results,
I noticed than going higher than 316x14 with the 3:4 memory divider, the bandwith begins dropping down so I think I will stay at 316:
At 316x14 we can see:
http://www.cyclopnet.pt/~nsl69249/316Sandra1.Jpg
http://www.cyclopnet.pt/~nsl69249/316Sandra2.Jpg
At 317x14 we can see:
http://www.cyclopnet.pt/~nsl69249/317Sandra1.Jpg
And at 318x14 we can see:
http://www.cyclopnet.pt/~nsl69249/318Sandra1.Jpg
You mean 316x14 with 1:1 instead of 3:4 ???
I can try...
But do you think I will get more memory bandwith ???
I meant that see if bandwidth drops at 317mhz FSB with the 1:1 divider
You may also try to get low latencies at 1:1 - may yield even greater bandwidth.
