http://www.coolaler.com/ipb/index.php?showtopic=32646
Can u post a pic of the Vcoremod ;)Quote:
Originally Posted by bigtoe
Do it need a 50k or 100 k ?
Thx
what's the max vcore and vdimm without a vmod?
Between this one and the MSI neo2, or the future DFI lanparty (nf3 one), who's the better for oc and performance? Because DDR670 sounds sweeeeeeeeet :banana:
maybe this 'll help ;)Quote:
Originally Posted by Cranox
don't mind the red and yellow circles and crosses, the people that were working on the mod originally encircled all the voltage related chips and then crossed out the ones that weren't the ones they were looking for. the only ones that matter carry the explanation in red text in the white backgrounds.
*edit* for those that already have the board, any comments on this? it's from a thread here but I couldn't find it anymore, luckily someone also posted it on madshrimps ;)
pros
runs great with ocz eb
runs great with bh5
runs great with ballistix
runs great with tccd
uses the 5v rail to derive vdimm
port80 diagnostic display
cons
problems with 512mb sticks latest bios seems to fix this
WARNING! do NOT use the ocz DDR booster on this board! vdimm above 2.8v will fry a mosfet and kill the board!
coldboot issues, random crashes and freezes from usb hardware (mouse keyboard printer etc)
cant run command rate 1t in slots 1&2 latest bios seems to fix this
vdimm is stuck at 2.7v and wont rise seems to work fine for some people
cpu temperature not reading correctly seems to work fine for some people
vcore ovp at 1.9v
only memory without a heatspreader will fit in slot1 with an xp120
If you can follow my setting, and using the 2T set running the 8k speed. You winQuote:
Originally Posted by trans am
If you can't follow and you lose
So right now the USB's are not functional?
I also own this board and realy like it :)
This is the max i got this out of it :D
http://home.quicknet.nl/qn/prive/pjm..._2.5_4_3_7.JPG
It has got some probs. with the memory and bios.
Like bigtoe says it needs a bios to fix this.
I also think its mucht better than the msi seems much faster working with apps somehow.
I can only run this high in slot 3+4 ... when i put the ram in 1+2 the system is very unstable ... cannot even get 10x 250 stable ... timings doesnt matter ... :mad:
my insert dimm1&dimm2 :)Quote:
Originally Posted by SmokeyTheBandit
so ur meaning is EPOX as good as MSI ?
last summer I thought " ... will choose EPOX"... but... now think that MSI sound better..
here is a new unofficial beta bios md34b25 :)
9NDA3+ IS BETTER THAN NEO2Quote:
Originally Posted by Zanr Zij
Originally Posted by jlccarv
iam also browsing a bit for a possible amd64 purchase..
and the epox is "here in germany" in the same price level as the msi
to be exactly it € 5,- more expensive
and better ?Quote:
wrong answer, it's definitely 1t CMD ;)
This has been said a number of times already :stick:Quote:
Originally Posted by Jeager
Originally Posted by windwithme
On my 9NDA3+, dimm slots 1 and 2 are stuffed when using 2x512MB modules, in dual channel (of course). Test 6 in memtest reports 1000's of errors at stock. In dimm slots 3 and 4 they run perfectly.
Whats more wierd is that, 2x256MB modules work a charm in dimm slots 1 and 2....
Im using the 10 Nov 34b10. I tried to flash the beta 34b25 (ALT+F2 method), but it stalled before it flashed, I'll try again soon...
I've never used the Neo2 Plat, so I cant compare the two...Quote:
yesQuote:
I Use over 15 slices of MSI K8n neo2
9nda3 is + better than neo2 in exceeding frequently
Can u show me BIOS setting best 4 9nda3+ with Winchester ?
And then after a while. Have I by BIOS it last test of respect not other , then can no photo that you need will be offered:)Quote:
I got the exact same thing with my 9nda3+ 2x 512 mb dimms run terrible in 1 and 2 :mad:Quote:
I flashed to the beta using winflash windows utility works like a charm !
What has BIOS which Could you tell me this edition improved? 9NDA3 of me use 256MBX2 in unable to start the machine DIMM3&4Quote:
Originally Posted by esoteradactyl
hey guys, what is maximum vcore w/ a winchester cpu, is it 1.6v via bios ? and if 1.6v is selected, whats the real vcore then about ? is it undervolting very much ? does the latest beta bios maybe raise vcore ? i think a decent board should at least give 1.65v effectively. :)
Yes she is better than the MSI but why ?
More stable ? better voltage ?
I know epox motherboard but tell me more plz :p:
If you don't need RAID same board for $92 @mwave.com :toast:
http://www.epox.com/USA/product.asp?id=EP-9NDA3J
Excellent work windwithme :banana4:
