Anyone figure out if the new beta BIOS for the MSI Neo2 Platinum does in fact cure the "cold boot" problem? I am also curious, as the only way I'd purchase this board and new cpu is to mate it with my Mach II
I've mentioned this before and i think 2-3 other ppl have said the 1.41 bios has fixed the cold boot issue. I've also said i would have mine back under the cold this weekend, more than a few times, but my new 3200+ retail is not going to get here till monday thanks to fedex so i'm kinda screwed :(
I'll definately let you know when i get mine set back up again.
Sounds great PnoT, I'll be looking forward to your update.
PnoT, how did the setup go?
i've tested my 3500+ winny with mach 1 on msi neo 2 with bios 1.2......1.3....1.36...1.41 and i've never got the cold boot issues
And thats the 90nm cpu?Quote:
Originally Posted by Boogotop
winchester = 90nm
so you dont have any problems with 90nm and phase cooling Boogotop? is your M1 stock? that might be it...
boogotop you are one of the lucky few.. I wonder what is different about your mobo or cpu.
don't know what the difference but i can assure all work good here
http://lesfurieux.net/hfr/for_3200mhz.jpg
http://lesfurieux.net/hfr/for_3500+%20Winny.jpg
perhaps it is your week?
I hope it is since I have one 440 3000+ on air here, and another 3200+ 90nm coming this week. if it is past 440 or so I will be tossing that one under my phase, if it is earlier I will prolly try the 3000+ even though its mem controller must suck, wont do above 260mem over EIGHT excellent dimms. does 300HTT x8 at 1.45v on stock cooler, have not tried higher yet but it did not seem to be breaking a sweat.
could be condenastion problems
cover all the component who are around the socket with sealstring
Any luck with the sub zero temps and the winnys?
Anything new with the sub-zero temps? Are the later week winnys doing better?
:D Don't blame the board - it's the winnie and nobody knows why. Some have a lucky punch and it works but mostly not, no matter of week or stepping. Go for FX.
:toast:
i am not 100% sure but in the most cases you could also use a cpu with newcastle core. So Fx would be the best but a newcastle should also work like the 3500+.
Maybe a winnie also works but thats not sure.
