doing all that just brings me to this screen:
http://xtremesystems.org/forums/atta...chmentid=18910
and i am using winXPpro SP1
i suppose it just doesnt work for my processor... :(
Same with my athlon xp. Oh well.
ok... so an a64 only tweak. so long as it doesnt mean off to AOL for me... ;)
Acctually I ment if you couldn't get to the screen to update your drivers, if the driver is missing that's a whole different story.
yea, thats why all this doesnt mean its off to AOL for me. ;)
to be honest with you guys this tweak is totally nothing new...Quote:
Originally Posted by pik-ard v1.1
as to your problem, pik-ard v1.1, you only get those two options for a simple reason:
when you were installing Windows you had an option in BIOS called "APIC" set as DISABLED... usually by default it is ENABLED. in that case after installing Winows you get all the options - as other guys get...
the only way to change it now is to reinstall Windows and make sure that APIC (not ACPI) option is EDIT:ENABLED...
at least on the NF2 platform APIC Enabled (ACPI Uniprocessor or Multiprocessor) has bad influence on stability but gives quite a boost in 3dmark01 and Sandra...
And there goes 33k w/ aircooled (+24C) Winchester rig :D
Winny + X800XT PE:
33056
Man I love T3h Tweak - and A64Tweaker of course :D
Macci what psu are you using?
my OC seems pretty low and am trying to narrow down what the problem is
- sorry for being OT
Ahhh its an apic thing? Yeah I disabled that so I would stop getting mouse/keyboard freezes. Actually I didnt notice any hit to 3dmark01 when I disabled it
i get the same thing on my winXP, with mobile barton, its weird cuz i was pretty sure i had APIC enabled in bios, but now.. im on a crap kt266 mobo, but... wait... that must be why i had to repair windows, because this board prolly doesnt have APIC or something.Quote:
whatever :D
so how many points exactly does this give?
on nforce2 it could give you up to 300-400 3dmarks. sandra bandwidth goes up about 20mb/s.... the only drawback is that at least on nf2 it's really difficult to maintain stability at very high FSB...
Originally Posted by macci
wow god that is a sick score for air cooling! I cant believe the IPC of winchesters, your only 80MHz higher than me but over 20fps ahead of me in car high and miles ahead in both lobbies! I really need a winchester now :D
that and use the ricky tweak ;)
C'mon guys, remove your give away postings and keep this tweak exclusive to XtremeSystems. ;)
I tried this and ran '03 with Win2k and didn't see an increase.
you gotta run 2001, 2003 sucks cause its very gpu limited so you might not see more than 10-20 marks gain but in 2001 it could be several 100!
That would explain it...but hell, I'll take 10-20 points now.
i dont think it would give an increase in 03 score? just a system dependant bench like 01? but im used to being wrong, so hit me with all u got :banana:
guys.. u should read this :
http://support.microsoft.com/kb/309283Quote:
HAL Options After Windows XP or Windows Server 2003 Setup
This article describes Hardware Abstraction Layer (HAL) options you can use after you run Windows XP Setup or Windows Server 2003 Setup.
MORE INFORMATION
Windows XP and Windows Server 2003 Device Manager list all the supported HAL options in a list when you click Update Driver. Unsupported options are not available. Microsoft Windows 2000 Device Manager permits you to select any HAL type. If you select an incorrect HAL, you may not be able to start Windows 2000, or you may have other issues.
When you install the following HALs on a Windows XP-based or Windows Server 2003-based computer, the following device manager HAL options appear:
"Standard PC", Non-ACPI PIC HAL (Hal.dll)
• Standard PC
"MPS Uniprocessor PC", Non-ACPI APIC UP HAL (Halapic.dll)
• Standard PC
• MPS Uniprocessor
• MPS Multiprocessor
"MPS Multiprocessor PC", Non-ACPI APIC MP HAL (Halmps.dll)
• Standard PC
"Advanced Configuration and Power Interface (ACPI) PC", ACPI PIC HAL (Halacpi.dll)
• Standard PC
• Advanced Configuration and Power Interface (ACPI) PC
"ACPI Uniprocessor PC", ACPI APIC UP HAL (Halaacpi.dll)
• Standard PC
• ACPI Uniprocessor
• ACPI Multiprocessor
"ACPI Multiprocessor PC", ACPI APIC MP HAL (Halmacpi.dll)
• Standard PC
Notes
1. A common symptom when deploying the incorrect image to a computer is that the Sysprep image stops responding on restart or reports a
Stop 0x0000007b
error message.
2. If an incorrect HAL is forced during Setup or by using a System Preparation Image (Sysprep), you can see the correct list of HALs only if you perform a new installation of Windows XP or Windows Server 2003. You cannot change to a HAL other than what is listed in Device Manager.
3. Device Manager does not permit the change from a Non-ACPI HAL to an ACPI HAL. You must use a new install of Windows XP or Windows Server 2003 for this type of change. Change from an ACPI HAL to a Non-ACPI HAL only for troubleshooting purposes.
4. On Windows XP and later, the ACPI Uniprocessor HAL and the MPS Uniprocessor HAL recognize the existence of more than one processor and report the MP ID. Plug and Play detects that the computer devnode's hardware ID list has changed and moves the devnode back through the "found new hardware" detection process. As a result, when you add a second processor the MP files (HAL and kernels) are automatically installed, and you do not have to manually update the driver in Device Manager.
5. Microsoft does not support running a HAL other than the HAL that Windows Setup would normally install on the computer. For example, running a PIC HAL on an APIC computer is not supported. Although this configuration may appear to work, Microsoft does not test this configuration and you may have performance and interrupt issues. Microsoft also does not support swapping out the files that are used by the HAL to manually change HAL types.
6. Microsoft recommends that you switch HALs for troubleshooting purposes only or to workaround a hardware problem.
7. When you create a Sysprep image, the image must contain the correct HAL type for the target computer. The following list describes the computers that you can deploy a particular Sysprep image to based on the HAL type in the source computer: • You can deploy a Sysprep image created on a computer that uses a Standard PC, Non-ACPI PIC HAL (Hal.dll) to a computer that uses the following HAL types: • Standard PC, Non-ACPI PIC HAL (Hal.dll)
• You can deploy a Sysprep image created on a computer that uses an Advanced Configuration and Power Interface (ACPI) PC, ACPI PIC HAL (Halacpi.dll) to a computer that uses the following HAL types: • Advanced Configuration and Power Interface (ACPI) PC, ACPI PIC HAL (Halacpi.dll)
• You can deploy a Sysprep image created on a computer that uses a MPS Uniprocessor PC, Non-ACPI APIC UP HAL (Halapic.dll) to a computer that uses the following HAL types: • MPS Uniprocessor PC, Non-ACPI APIC UP HAL (Halapic.dll)
• MPS Multiprocessor PC, Non-ACPI APIC MP HAL (Halmps.dll)
• You can deploy a Sysprep image created on a computer that uses a MPS Multiprocessor PC, Non-ACPI APIC MP HAL (Halmps.dll) to a computer that uses the following HAL types: • MPS Multiprocessor PC, Non-ACPI APIC MP HAL (Halmps.dll)
• You can deploy a Sysprep image created on a computer that uses an ACPI Uniprocessor PC, ACPI APIC UP HAL (Halaacpi.dll) to a computer that uses the following HAL types: • ACPI Uniprocessor PC, ACPI APIC UP HAL (Halaacpi.dll)
• ACPI Multiprocessor PC, ACPI APIC MP HAL (Halmacpi.dll)
• You can deploy a Sysprep image created on a computer that uses an ACPI Multiprocessor PC, ACPI APIC MP HAL (Halmacpi.dll) to a computer that uses the following HAL types: • ACPI Multiprocessor PC, ACPI APIC MP HAL (Halmacpi.dll)
i had problems and :banana::banana::banana::banana:ed up my xp installation! because u cant change from a non acpi HAL to a Acpi Hal
but i used it on xp SP2 + 2500+ mobile@Nforce2
so becarefull.. and use it wisely :P
_zZz_
Works perfectly fine on my P4 2.66ghz and 2500+ :)Quote:
WinXP SP0 :p
Sure that 9500np isnt slowing you down???Quote:
Originally Posted by Geforce4ti4200
running xp i didn't even have that box. it was all compatible hardware on an xpm 2600+ - btw i think he's in the wrong item in dev.manager anyway :DQuote:
Originally Posted by craig588
Nice post _zZz_ Tk's
same stock setup 12x200 only this time small OC on the GPU
610/605 xt clocks air cooling 1.5v
http://service.futuremark.com/compare?2k1=8224225
Click for Large Pic
http://jason57.iwarp.com/255sk8v/299small.jpg
all stock vs overclocked gpu
http://jason57.iwarp.com/255sk8v/ocvsstock.JPG
Very sweet air-cooled score there Macci :D
