Re: Re: Re: Re: Epox 8K9A2+ Vcore mod.
Originally posted by RoydRage
Hi,
What I really meant was the board stable with the mod....
Ow ghehe :D The board is fine. No problems at all. Still maxed out on 2154Mhz :mad: That was my max on the KR7A as well. I was hoping the KR7A was unstable due to fsb limitations.
I pull 14K 3DMarks with this setup. Pretty happy with that.
Did you use a Magnifier light when you did the soldering... There are techniques that were developed dating way back to the Kt-7... For this soldering... I lot of us have gotten quite good at it.....
I have a 50k pot on had.... Did you get a chance to measure?
Thanks, Royd
I used nothing to do the soldering. Stupid, I know. I didn't have anything. But I pulled it off :toast:
Techniques? Tell me..
I put solder on the wire and on the pin. Then I put the wire against the pin and touch it with the iron. The iron is about 310 C. It had a little knob for the temp (Weller EC2002).
How do the chips cope with the temps while soldering. Is that something to be concerned about?
I will take the pot off now and see what it measures.
Edit:
Ok, I measured it and it read really low. 1K Ohm for a max of 2,2V with bios @ 2,00V ofcourse.
I couldn't see how far the pot was because of the metal shaft. I marked it with a marker now.
So a 5K pot would do. A 1K resistor is also good.
On 2,2V it reads a little over 1K. Say 1030 Ohms.. But I recommend you use a VR, That way you're safe and you can turn the vmod off if you want.
Re: Re: Re: Re: Re: Epox 8K9A2+ Vcore mod.
Edit:
If you could do that with no magnifier you're better than me....
You did the right thing.. use a small wire, and twist it tight... Put a small bubble of solder on it. and then cut it.. So you have a small bell shaped piece of solder, and hold it to the pin, and just touch it till it melts.. Stay low near the board, and not so close to the chip.... And it should survive. <Edit... Didn't see you had C. for Iron Temps...
I like using a fixed resister, cause it can't drift, or get bumped working on the board. I also have a great assortment on hand so I could do it today... Are you sure about the value? You disconnected the pot correct?... It's just that 1k seems kinda low...
Thanks for your work! :)
Royd.... Oh.... 14k seems like a pretty could score I got 13k with this board and a faster OC then you... A stock Ti 4600 though...
Re: Re: Re: Re: Re: Re: Epox 8K9A2+ Vcore mod.
You did the right thing.. use a small wire, and twist it tight... Put a small bubble of solder on it. and then cut it.. So you have a small bell shaped piece of solder, and hold it to the pin, and just touch it till it melts.. Stay low near the board, and not so close to the chip.... And it should survive. I use a higher temp to melt it quick... about 620F....
Ok, what I did:
- Put vcore on 2,00V in bios
- Save changes
- Restart
- Enter bios
- Put on 2,2V with VR/Pot
- Shutdown
- Put mark on shaft and housing of pot in case of turning while disconnecting
- Disconnect pot
- Measure with Fluke
- 1030 Ohms
- Pot was almost turned all the way (wich is correct on a 250K pot)
http://www.fewture.cistron.nl/img/8K9Avmod.JPG
I figured maybe 10K VR is better and safer...
Any comments or tips??
Edit:
There is a typo in the image! OMG!! :D :D <--fixored..
