The node # is also hard coded. This makes for interesting problems. Say you wish to wipe out a RH 8 install and put Libranet 2.8 on the same box and want to keep your same node number. In most DC projects, you simply enter your email or user ID and off you go,; not so in D2OL. You will need to copy the node.prp file (for safety's sake I always copy the entire directory) to a safe disk, install your new distro, install the D2OL client (which will generate a new node #), let it finish initializing, quit the client and then copy your old node.prp file over the new node.prp file. Convoluted yes, but at least you can keep your node # tied to a specific machine. Additionally, it is wise to reuse your node #'s as NOT reusing will leave you with multiple "dead" non-productive node #'s. The node.prp file does not just contain your node #. It is a derived file (hashed/encrypted/encoded) containing your node # and email addy so you simply cannot type in it without destroying it.
I was worried about having dead nodes as I want to publish my farm status on my web page. Now if I need to re-install I can keep the same nodes :toast:
