Originally Posted by Sampsa
Ok Vtt-mod is working. I used the same method what Goldlocke used with KV8-Pro.
1. I removed 0 ohm resistor next to Winbond chip pin 7
2. I replaced it with 10 ohm resistor
3. I soldered 1 kilo ohm VR between 10 ohm resistor (the pad which is nearer Winbond chip) and GND
VR should be set to MAX and lowering the value will raise Vtt
I'm now installing Windows and I'll post the results later. Currently running Vmem 3,02 V and Vtt 1,51 V.
Thanks for your help everyone!
:toast:
