Rebooted computer at least 50 times yesterday.
Can boot win with 315 but never get it prime stable.
Going back to see what max 2.5-3-3 can bring.
What is the max stable with the timings BigToe recommanded?
Did you try SuperPi 1m?
Cant boot with bigtoes settings.
Will try superpi later but my cpu max at 2.4 so there is no good setting for multi at 310
do u have 1 512MB-stick or 2x256MB? :)
first i'll try those ram, and then (if i get bad results) going to A-Data DDR600....:)
I believe he has 1x512, because the mems are only availably in 512mb/2x512mb.Quote:
Originally Posted by p4z1f1st
so Ubermann: what are your max results, with your maximum voltage? (afaik u've the Lanparty-UT - so push it to 3.1V :D)
but i want to know 1T-results....2T sucks on A64 :D ;)
Best i can get in PI is 35 sec, best i can get in sandra i 4900 something when its pretty stable.
Only benches i have tried.
CPU refuse to go past 2.4gig
Able to boot win with 325fsb and cpc on and cpu at ~2 gig.
Pulled back to 320 and took a screen.
That, my friend, is some serious bandwidth!! :up:Quote:
Originally Posted by Ubermann
yes, that's amazing.....
DDR640 would be PC5120 - so in a "optimal" way he should get 5120MB/s
and he's getting amazing 5000MB/s (with loosy timings) :)
oh man, i've to w8 for my next fee, then i'll get 1gig of that amazing RAM :) and maybe a OCZ Booster ;)
WooW!
That ram looks perfect man!
I am waiting for my DFI by the end of this week or the begining of the next and i am going to test my crapy Corsair pc4400 on it(does max 230 on my ZNF-250 no matter the settings...) and if they perform so poorly on the DFI as well,i am going to get some OCZ PC3200EL Plat rev.2 :D :D
Ohh from where did you got them and how much??
Keep up the burning :D
I am also ordering some of this stuff...You can get it at NewEgg.com or hereQuote:
Originally Posted by Samael
http://www.atacom.com/program/atacom...RCH=SEARCH_ALL
Thanx but US is not an option since i live in Greece(EU)....
Also,does anyone have any idea on how we can be sure its a rev2?
Is there a sticker or something?
EDIT
Just found them at Shop 4 memory (UK) for 328 € for 2*512.
Is this considered to be a fair price??
yes - in germany they cost about 300€
Ran memtest #5 and #8 (#5 for adults :D)
255 FSB, 133 div, 383 HTT (LDT = 2.5) x 6 (best memtest BW) and ran fine all night. :banana4:
Computer hangs at Drive detection @ 418HTT, 120 div :shrug:
May not survive the winxp 32 install in a day or so, but I like it so far. Gotta run some more memory tests b4 loading winders.
Max async Latency has to be btw 8-10 or it will result in "detecting array"
Speeds over 315 with one stick 512 has to run at "ram strength" level 2
Write cas TWCL should be set to AUTO or 1 (prefer auto)
"Refresh period" should always be set to 4708
DQS Skew should be increase and a value btw 8-128 (Over 320FSB 8 to 32 max)
This is with CPC on.
I could be wrong but i played alot with this and think this is correct settings for high FSB on this ram.
Correct me if im wrong, dont even know what most of this settings do =)
Ok, I finally have some results to share with my 2x512 Plat Rev2/DFI/CG clawhammer setup. So far, I am running at 250MHz x 10 and memory set 1:1. Timmings are 2.5 3 3 10 and thus far I am getting 3900 in sandra and 35 seconds on super PI. I am really liking this machine so far. Not too shabby for an air cooled dual 512 stick setup if you ask me.
Oh yeah, I haven't tried just a single stick so far, but the hightest HTT I have gotten with both in the system and being PI and Sandra stable is 320 1:1.
Originally Posted by Cohiba
Not bad. I want to hit about 8,000 MB/s. Do you think this goal is attainable? My matched pair of (2 X 512) OCZ EL PC3200 PE Rev 2 will be here Friday so I guess we will see.....
Your guess is as good as mine :p:
I haven't seen too many results with other 1gig configs, so I don't know what is to be expected of it. I have no idea what setup you will run it in either. Also, I am sure a dual channel setup would get better results than a single channel setup such as mine. What I can tell you is that this memory is damn good. I am more than pleased thus far with my results, and I cannot wait to see just how far I can push it. So far, this memory has gone as far as I have asked it to and begged for more. As it sits, it is sandra, PI, and prime stable. Things were a little shaky at first since the PSU I was running just couldn't cut it and undervolted like mad. Since I got my new one in, voltages have been steady and plenty, and my system and my memory have responded very well indeed.
How high did you get with 2.5-3-3 Ubermann?Quote:
hm... seems like my mb is my bottleneck.. i cant run sandra memory benchmark over 295fsb(with 1 stick).. it doesnt matter what timing and ive tryed vdimms up to 3.3v . ill maby try more today.
im useing 2x512mb ocz 3200el rev2.
right now im trying to get both sticks prime95 stable.
i got error after 1h 30min with 270fsb 2.5-3-3-10 and 3v.
error after 1 min with same settings exept 265fsb. so now im trying 275fsb instead.
Hmm..talking about volts,how do they react in high volts??
Since i heard that TCCD are not a great fan o Tera-Volts :p
Havent had time with 2.5-3-3 yet.
Lost a whole evening trying to boot at 330FSB cpc on.
But i lost that fight =)
But 2.5-4-3 works at 315fsb.
Just trying to get it stable now.
2.5-3-3 seems to max at 280~285, after that its 2.5-4-3
thats pretty good! thanks for that Ubermann
