It blew up like a party popper, a white silly string like substance stuck to everything in its path.
CC, good to see you around.
I agree, we will need to hit ~10c beyond condensing temps of the next stage to be safe. With the expansion valves ability to maintain temps under load we dont have to get excessive here to maintain the capacity of the load. With a cap tube I can see where this would be a problem.
We need to hit -100c on the second stage @ ~ 20 psi to get the methane condensing.
A bypass valve may also help on restarts to equilize the pressure and prevent another blown compressor.
We needed a video of last night, two blown compressors (one doa, had start problems on first stage unloaded with R507), A blown cap.
Once running we had no problem getting the first two stages going in no time. They ran for hours and we swapped out the third stage compressor after failure with the first two stages running.
