Yea, my bad; I guess I was a little unclear on that part
I have a early co stepping amd64 3200+ that does 2.5 on air and water. and a mobile 3200+ cg that does 2.65 stable too, so you are wrong again!:banana:Quote:
Originally posted by boshi
watts matter because they allow you to turn up the voltage farther.
also, I dont know where you're getting your info, but a clawhammer 3200+ isnt gonna do 2.5 on air or water.
first of all 62w 3200+ only come in clawhammer CG stepping. (10x200)Quote:
Originally posted by airjetline
Cooling? Vcore? Stepping?
default vcore is 1.4v
thermalright heatsink will do. I'm using water (mcw6002-64)
read more here:
http://www.xtremesystems.org/forums/...threadid=41252
Guys, when it all comes down to it, all the crap about the max a chip will do or the minimum it will do is all speculation. Yeah, we can all compile tons of data and more accurately guess what a chip might be able to perform at, but when it all comes down to it, its pointless to say a chip will for sure top out at 2.5 ghz or that it wont make it too say 2.2 ghz in the first place. You buy a chip and all you know for sure is that it will do the specs it was sold for ( unless its somehow broken). And obviously, it'll probably go higher, but ( and i certainly am not intending to point any fingers or flame anyone ) it seems like too often there are posts telling someone exactly what they are gonna overclock to or exactly what it could at least be. sometimes i wonder how many people get bad information because they trust all the crap that is sometimes said.
so here is my answer for your original question airjetline....i think for what you wanna do you should get a dtr. the cache certainly has an important increase and they seem to overclock well. mine certainly does. the newcastle chips from what i have seen do tend to overclock probably to a higher frequency, but as far as is if its enough to beat out something with a larger cache depends on how fast of a cpu you end up getting. and who knows, maybe a dtr will hit 3 ghz on air and do what seems to be unimaginable and maybe it wont even overclock at all. its the chance you have to take in this hobby
Hello,
A64 Mobile LV 35 Watt 1.2 V 1.6 Ghz 512 Ko 2700+ -> AMD2700BQX4AX
A64 Mobile LV 35 Watt 1.2 V 1.6 Ghz 512 Ko 2800+ -> AMD2800BQX4AX
A64 Mobile 62 Watt 1.4 V 1.6 Ghz 1024 Ko 2800+ -> AMN2800BIX5AR
A64 Mobile 62 Watt 1.4 V 1.8 Ghz 1024 Ko 3000+ -> AMN3000BIX5AR
A64 Mobile 62 Watt 1.4 V 2.0 Ghz 1024 Ko 3200+ -> AMN3200BIX5AR
A64 DTR 82 Watt 1.5 V 1.8 Ghz 1024 Ko 3000+ -> AMA3000BEX5AR
A64 DTR 82 Watt 1.5 V 2.0 Ghz 1024 Ko 3200+ -> AMA3200BEX5AR
A64 DTR 82 Watt 1.5 V 2.2 Ghz 1024 Ko 3400+ -> AMA3400BEX5AR
In CG Core :)
Best AMD CPU is A64 Mobile 62 Watt 1.4 V 2.0 Ghz 1024 Ko 3200+ -> AMN3200BIX5AR
Bye ++ :)
