yes, because the card tries to take the power it has gotten from the secondary PSU, and use the ground through the motherboard from the primary PSU, which results in the prepackaged smoke which is sealed in during the manufacturing process, to be released from the card, rendering it unusable.Quote:
Originally posted by spaceman
Seems like if you used the secondary PSU for your fans & drives, and left everything else hooked up normally, it should be OK. :confused: I think I'll choose NOT to be the guinea pig for this test tho. :p: ;)
