Those are some nice scores.
How far can you get with the asus board.
Also did you really hit 380fsb with the dfi 925x board.
360Mhz on the DDR2 with the 3:4 ratio @ 270FSB slack timing with the Centon. I will find the top end of the corsair. It should be much higher.
Trying for 300FSB DDR800 now on the Asus. My multiples are not working on the Asus and swapping out to the 2.8e
Im kinda picky, I want to post screen shots that are stable w/benches before moving on.
understood.I am going to be testing the albatron 915P board tomorrow.
I need to get another cpu.I dont want to kill the one I am using for testing.
Will test it with the albatron pcx5300.
sligthly offtopic but isnt the Spi run a bit slow is is just me?
Its about right since the ram is running at stock speed.
Hello! I have been playing around with my new system and this is what I came up with in the end.
http://www.geocities.com/mxvelocty/D...3-10_346-2.JPG
I lose my SATA drives if I go any higher FSB. Trying to get an answer from ABIT about it. Using the AA8 Duramax board with a retail 2.8E.
very nice stuff .. 3.4EE LGA775 :cool:
El.Padrino Welcome to XS!
You have exceeded geocities bandwidth allowance =(
You can attach the image with the "post reply" button.
Thanks EVA2000, I will be on EM64T soon. Just a little something to hold me over untill. If you have some database tests let me know.
Attached screen shot. Time to get another place to host pics.
2K1 at 4.43Ghz, I still cannot submit scores for 2K1 and 2K3 on LGA775
Sandra resets back to zero after 4.3Ghz, no sandra because I lost control of multiples in beta bios 52
Ownage for a 5700 class video card with no OC.
woah nice :)
does this mean ya have a 3.4EE ES lying dormant ? :D
I just got back my P4C800 from RMA and my S478 3.4EE ES is about to get more abuse. The last mobo started to fall off and eventually died a horrid death when it blasted a moset off the board.
I have a 6800U to torture with it. I will post screen caps of both X800XT and 6800U at top end to show the image quality :D
:eek: how far did it fly ? :DQuote:
I never found the part
Pulling up to 4.5Ghz now, DDR700. Benchmarkable at that speed. I wish my multiples worked!
fugger you go boy.
I got ya beat with the with my 5750.
Dont make me OC this thing!
What score did you end up with?
15k
That a real 5750 or a slower card like a 5350? Seems low to me for a 5700 series card.Quote:
Still set to quality with no OC.
Downloading rivatuner now...
So it was a 5750, that seems a good score now...
Oh crap what did I start now.
lol, hes going for your 15K I bet ;)
to bad the 2k1 orb doesnt allow you to select fx5750 :(
Shut down and going home, rivatuner loaded.
Default clocks 425/500
