i think it performs the same...
Where is everone geeting the fans at? i need a smaller one for the chiller and can not find them.
Lotec25
i think the slide glass needs to be before the drier
kayl you r right... i will change the setup in few days...
1 Attachment(s)
from +30 to -34 took it 4:30 minutes...
1 Attachment(s)
1 Attachment(s)
-18 under the load of a 226watt peltier...
1 Attachment(s)
my tec dont love ice.... i dont know why...
Stick it on the gpu man!!We are whaiting your results!
power the tec with 9v if ya can
also try sticking the hot side directly on the direct die block and make sure you use heat paste
sticking the thermometer on the side of the direct die block then insulate the hole lot
this will give a better idea of the temps might get.
also you need better clamping than cable ties, heat transfer will be very poor, you might damage that tec if not carful
try a g clamp or something
Lotec25:
Do a search on RSWWW, maplin or ebay for '120mm fan'.
wrong fan i am talking about the one on the condenser
Lotec25
1 Attachment(s)
i did the changes...
is it ok now?
1 Attachment(s)
some more pictures...
I put it on fx5200 just for test without insulation...
1 Attachment(s)
this card on air from 275 can 285
on water 300 and on phase change 354
1 Attachment(s)
1 Attachment(s)
here i think it is at 15 loop...in 3dmark01
I want lower temps... maybe if i change the capilary? What diameter and what lenght?
1/5hp+507
What are you using now.. and what is your evap pressure?
If you haven't insulated the evaporator, you really need to. That would help your temps a bunch.;)
i thought that with 507 i can do -50....
1 Attachment(s)
with little tunning... :) :)
1 Attachment(s)
i think that i have to change 507 to 410... How long do u think that it must be the capilary tube?
Unseen, what braiding is that?
what "braiding " means? Sorry for my bad english....
