no clue but i didnt do that oneQuote:
Originally posted by LilGator
vdimm 3.3v direct mod? Just like the K8N 3.3v mod ?
VBT mod needed as well?
New bios
rev.2.0.0C
rev.2.0.0
D25 rev.2.0.0 01.08.2004 Cpc On 3.19 Bpl by -=Merlin=-
D25 rev.2.0.0C 01.08.2004 Cpc Off 3.19 Bpl by -=Merlin=-
-Timings Mod T(ras) (D25 rev.2.0.0 01.08.2004 Cpc On 3.19 Bpl by -=Merlin=-)
T(ras) 11 slowly
T(ras) 8 faster
-3.02 bpl auf 3.19 bpl
-Romsip Mod
-Cpu interface 200 Mhz Optimiert Romsip
-Power Management Mod (Suspend to Ram bei 250mhz Absolut kein problemm meher)
-COMMAND PER CLOCK (Cpc) Disable/Enable
All testet
Prme95
FFTmax 4096 // FFtTmin 4096 12st ...ok
3DMark 2001 ...ok
3DMark 2003 ...ok
mfg by -=Merlin=-
Thanks a lot Merlin, the d25 rev2 is the best BIOS I´ve used so far. Keep up the good work! :up:
should i use cpc enabled or disabled?
am using 2x512 hyperX ram.
cpc disabled will hinder poor preformance no?
n/m...:cool:
is there a builtin L12 mod in those bioses? and what about bandwith tweak?
?Quote:
Originally posted by blinky
...and 3.3v to vdimm direct mod
I only see bios for NF7...
... but i needed bios for AN7 heh :(
no, its for rev2s only , dont try it , it will :banana: :banana: :banana: :banana: it up
Here..I can send some more but at this time this was all i had screenis ofQuote:
Originally posted by by -=Merlin=-
someone can send DFI Sandra Bandwith 250,255,260,265,270,275 to me
and which dfi bios
And i messed up the clairity sizeing down so much
I will take another and see if i can beat it
Int bufferd 4084 263 FSB x9
Float bufferd 3753
This was TicTac 131 Bios:banana:
LanpartyB
2x256 OCZ PC3500 EB
2400 XP-Mobile
BB ATI 9800 Pro
Antec TC 550W
test
FSB 250 rev.2.0.0C Cpc Off
FSB 250 SSoft Cpc Off
this bios is very stable, I in long tested and nothing negative determined
cpc is like the command rate i believe... like 1T or 2T, cpc on performs better clock for clock... but cpc off yields higher ram oc.Quote:
The D2 bios was not stable for me... got occasional reboots surfing the net, DLing, and watching some video :(
Using two sticks of 256mb single sided HyperX BH-5. Ran them at 240, then at 230 and still reboots...
I am back to one of Tictac's d23 bioses...
@r3b0rN
Wow, who's that chick in your avatar??? :slobber:
This is the best BIOS I've tried so far! I couldn't even overclock past 200MHz before without instabilities and stuff. Now I've been up to 235MHz 11-2-2-2 with CPU Interface enabled! :banana:
I'm using the 2D BIOS in the original post. Does this have CPC enabled or disabled?
Merlin's download links are broken?
I cant get it too~
http://forums.pcper.com/showthread.php?t=338953Quote:
Hi
New Bios
rev 2.0.1C
D25 rev.2.0.1C 03.08.2004 Cpc Off 3.19 Bpl by -=Merlin=-
-Romsip Mod 1-31
-Optimirung
-CPU Disconnect Function as recomended by nVidia tech
-Alpha Timing : 2-3-3-3-3-3-4
-T(rc) : 9
-T(rfc) : 12
-Dimm Driving Strength : 6
-Dimm Slew Rate : 7
very stable, very god
by -=Merlin=-
WoW Merlin!! keep up the good work m8!
let me know if u need any gunie pigs to test it on :D
btw...would u recommend cpc off?
its better for 1gig kingston?
I cant get access to the bios page... I get DNS error...hmmm
this problem is not well-known me, I tested
How many volts on the RAM?Quote:
Float bufferd 3753
LanpartyB
2x256 OCZ PC3500 EB
2400 XP-Mobile
BB ATI 9800 Pro
Antec TC 550W
3.3 Vdimm...
Maybe Abducted or someone could alternate-host the bios's. I'd luv to tes that 2.0.1C cpc-off version, but I cant get to the page... comes up DNS error.
New Bios
rev.2.0.2
rev.2.0.3
D25 rev.2.0.2 06.08.2004 Cpc On 3.19 Bpl by -=Merlin=-
D25 rev.2.0.3 06.08.2004 Cpc On 3.19 Bpl by -=Merlin=-
rev.2.0.2 neu Romsip Mod
rev.2.0.3 optimiert 3DMark
