Originally posted by berkut
This is a very nice guide, deserves a sticky...
Yes that is true, but how long do you have it on ? Maybe 1 second ? Later the oxygene rich gas flow will oxidize the soot as you called it
Tell me something about it :D This is dangerous in a hands of a noob...
I start my torch this way:
-tip pointing away from me ;)
-start mapp/acetylene
-fire it up with a 2nd torch or special tool
-turn oxygene on
this is a safer way of doing it.
when brazing a evap watch out not to push the tip of the torch too close to the evap, i had a accident when the evaporator filled up with oxy/mapp and exploded (the shockwave comming out of the sucktion line would burn my face if i havent had my welding mask on, gloves etc., yes i do such stuff in a welding mask, much safer)
When describing how to braze we should start with the dangers of using a torch. I think we should point out some stuff as well as give some tips.
