New cpu swapped in is promising indeed :D
3.2EE @ 247fsb 1:1
2X 512MB OCZ PC3500 Plat LE BH-5 @ 247mhz 2-2-2-6
Gecube X800Pro @ 564/605 = 14,156
http://www.fileshosts.com/pentium4/D...4156_small.jpg
3.2EE @ 247fsb 1:1
nice score little more cooling on gpu and 15k+ :toast:
Is that with the fresh install you're talking about before??
Just under 600 points from a re-run.... Not bad at all....
/whips into his spares tray to his secret weapon but no P4EE:D
AARRGGHH!!!
Whereabouts on the ORB are you now??
Cheers,
Minnyboy
nah haven't done fresh install yet.. swapped in my 9800Pro Extreme to do some last minute benchies on same OS state to see what 3.2EE can do for the old R350 core card then fresh install :)
edit: for X800Pro cards i think i'm 4th or 5th if you take into account non WHQL drivers and show only highest score per user
woah this 3.2EE is awesome... i swapped in my Gigacube 9800PRO Extreme and even at stock 3.2EE speeds it beat my previous best 9800Pro score @ similar speeds but it's 3.2ghz vs 3.92ghz!
Gigacube 9800Pro @ 486/810
3.2EE @ 200fsb = 3.2ghz 1:1 2-2-2-6 timings stock = 7,618
vs
Gigacube 9800Pro @ 484/805
2.8C @ 280fsb = 3.927ghz 5:4 2-2-2-6 timings stock = 7,612
Those P4EE's do have some balls don't they??
That's like Intel doing an AMD on themselves....
Wouldn't be the first time though... Pentium M comes to mind here...
I don't think there's anyway of me catching you anytime soon lol...
Not bad for stock cooling material...
I am right about you using stock coolers aren't I??
Well, aircooling anyways...
Putting most of the big Phase-Change Coolers to shame:D :D
I would've thought my Powercolor wouldn't be that far behind in benchies against the GeCube... Within error margin was what I was thinking....
Time to sell the missus for some AUD$700 odd for a 3500+ or AUD$1050:eek: :eek: :eek: :eek:... The a kidney for a mobo & I'll be back.... minus 1 kidney lol...:D :D
Cheers,
Minnyboy
3.2EE is on Corsair Hydrocool 200 water cooling
while X800Pro is virgin stock untouched card :)
it helps to have the Abit AI7 canterwood killer board too :D
Might have to break it in soon eva....Quote:
Wanna see an Aussie at the top of the 3D Charts mate....
Been a while since there was a contender....
Back when Creative was in the game iirc....
Time to add some hs to the memory & whack a nice cool waterblock on her too....
C'mon Aussie C'mon
Oi, Oi, Oi....
Cheers,
Minh
lol...i'll try my best but all stock mate...
dam car low bug + drag high lower than usual so probably can get another 100-180pts
but for now
Gecube X800Pro @ 560/600 = 29,731
update:
Gecube X800Pro @ 559/605 = 29,876
http://www.fileshosts.com/pentium4/D...04_29876_1.jpg
Okay,
Here's the deal...
P4 3.0c @ 4.05Ghz
2x256MB XMS3500 @ DDR433 2-5-2-2 (GAT: a, e, 5, e, e)
IC7-G Vdimm/Vtt mods 5:4 divider
X800PRO @ 600/590 (iirc)
Vapo PE Ti, Watercooling on GPU...
Only 26,318 3DMarks....
Yet a P4EE at lower fsb/mhz & lower X800Pro gets over 3K more than me:confused:
I thought the P4EE did give some more marks but 3k:confused: :confused:
It's a conspiracy!!!:p:
Good job eva2000.... Makin' us Aussies proud there mate...:toast:
Minnyboy
BTW, like my new little avatar?? Stolen from the one, the only OCAU forums:D :D :D
lol at avatar... whos is it again ?
P4 EE really give ya boost :D
don't forget my ram speed and size is
2x512MB BH-5 @ 248mhz 2-2-2-6
versus
2x256MB BH-5 @ 216mhz 2-2-2-6
and i'm running the canterwood killing, Abit AI7 springdale board :D
eva2000 do you have a 3DMark03 approved score at 14xxx points?
you mean WHQL driver one ? i have the 2.8C@280fsb 5:4 one using cat 4.6 but that's 12,259 http://service.futuremark.com/compare?2k3=2665134Quote:
haven't done one with my new 3.2EE yet, but just freshly installed winxp with cat4.6 now so will get around to 3.2EE + X800Pro WHQL approved score :)
nice as always
very very nice work eva2000, all ur hardware is top notch :slobber: cant believe u got 2x512mb up to 248 fsb, wow... keep up the good work. any plans on an x800xt or are u content with that NASA approved machine? lol.
ps - that guy meant futuremark approved drivers.
yup 2x 512MB OCZ PC3500 Plat LE BH-5 @ 248mhz 2-2-2-6 at 3.18v vdimm on AI7 which already gives that by default no mods :)
X800XT if the price is right or someone generously sends one my way I'll try it out on my 3.2EE system :)
so tempted to dust off my Mach2.. but will wait for OCZ DDR Booster + P4C800-E + Mach2 + X800Pro hehe
Well did my first oc'd Aquamark3 run and got 72,618
With Gecube X800Pro stock air cooled unmodded virgin of a card, that score ranks me @
#18 any cpu & any video card
#11 P4 cpu & any video card
#3 P4 cpu & X800Pro (420) series which apparently includes X800XT as well!
Against 6800Ultras
#7 P4 cpu & 6800Ultra category
#11 any cpu & 6800Ultra category
Well been trying different catalyst drivers and the each driver i try is lowering my max core oc! max ram oc stays the same though. This is mainly for 3dmark2001
4.7beta max core 564mhz <-- lowest 3dmark2001 numbers!
4.6 official max core 559-564mzh
4.5 official max core 553-559mhz <-- so far still get the highest numbers in 3dmark2001 mark even with lower max core oc ???
how high you may ask ?
P4 3.2EE@200FSB
1GB OCZ PC3500 Plat LE BH-5 @200mhz 2-2-2-6
Gecube X800pro@562/604
cat 4.6 drivers = 25,070 from winxp reboot
Gecube X800pro@553/600
cat 4.5 drivers = 25,291 still in same benching windows session without fresh reboot!
Also seems ATI Tool 0.0.20 doesn't like cat 4.5 driver and trying to load a 2D/3D profile at startup as it crashes it ???
Gonna definitely break 30k by end of this weekend :) First Aussie to do so ??
Gecube X800Pro @ 553/604 = 29,932
update:
Gecube X800Pro @ 553/605 = 29,996
4 more pts!!!
http://www.fileshosts.com/pentium4/D...04_29996_1.jpg
C'mon Aussie, C'mon!!!:toast:
A measly 4pts... You can get there mate.
Sometimes I do a run & compare the lowest points from different runs & then just re-do that run til I get that extra fps....
That's how I got 24K with my 2.6c/9800pro combo...
Good to see ya up there mate.
Cheers,
Minnyboy
Don't ya worry will definitely crack 30k by tonight :D
Still waiting for OCZ DDR Booster before P4C800-E/Mach2 action. so might finally order MCP600 pump so i can setup alternative water cooling to my Corsair Hydrocool
First time DIY job
Silverprop Cyclone SE
Bravo heatercore - waiting still
Clearflex60 1/2" ID
MCP600
two 120x38mm Delta 190cfm fans LOL
wonders if i can push my 3.2EE over 4ghz then ? :)
I can hear the Prommie calling the 3.2EE's name....
"cool me, cool me":D
Then we'll definitely see you near the top of the charts for 01 & 03....
As for me, my bank is running dry lol... Especially after 3 dead CPU's:mad:
Won't see me anywhere near you soon....
Good luck with the other WC setup.
How's about one of Cathar's blocks?? I'm pretty confident you could get one off him.
Nothing beats those Delta's mate... In my eyes anyways.
Where to get them in OZ?
Cheers,
Minh
