any who can help me please...??
an7-barton 2500+@2500Mhz(250*10)vc 1.75 vdim 2.7,5 CL 3-3-3-8
gecube 9550 extreme edition 128m 128 bit
aogem 450 w
a-data vitesta pc4000 ddr500
polo735 by thernaltake
===>>>>stabil and power...
can help me with @3000Mhz or more...??
SAme Prob here ! 1,9x V is stable ,bur all over 2V isn`t ok.
aogem 450 w
http://www.xtremesystems.org/forums/...te=1&p=706861# new fsb guy's...>>>>260
but with multiplier 8...
huh...not power to be me....
not mod vdim or vcore
who can help me with fsb 266.....<<<<< please
with anything.......
Wow!... the mod works OK! :toast: :banana: :woot: will only bring it as high as the 3.3v rail...
so do the 3.3v rail PSU mod here or HERE
problem is that the AN7 won't read past 2.48 in the bios... it 'will' actually go higher than that... but it won't show... you have to measure it with a multi-meter from the DIMM slot... the interesting thing is that my Vtt tracts properely... I've pushed the Vdimm all the way up to 3.8 (checked with multimeter) and the bios reading for vtt was 1.90...
very cool thx for the help...
ofcourse if you do this you have to reset Abit EQ... anything past the current 3.3v rail setting or the vDDR setting will cause that stupid 2 tone siren to go off.. and since the highest you can set the DDR is 3.5, if you push past that like I did you can no longer use Abit EQ..... no biggie, use MBM5... if you do get that siren, just turn off Abit EQ (siren will still sound), make sure it isn't set to start automatically with windows, turn off the computer, clear the CMOS then don't run Abit EQ and return to your overclocked, overvolted settings.
thx
p.s. Get the AN7 Vdd mod HERE
