Originally posted by Gary Lloyd
Cap tubes are sized for a specific heat load. You can't tell if they are right or not until the evaps are fully loaded, not to mention insulated.
You do have the longer cap tube on the GPU evap, right?
Yes I do think so, but I've cut bits when testing after brazing so now its a bit of a ?. I've put in a bit extra to account for the cutting, I intended the GPU to have 0.2M of 0.026 longer, but I think now they're quite close in lengths. Think I'll shorten the CPU cap length.
