im getting as5 tommorw and goig to flash pc with bios 15 tommorow
but after alot of messing about it is runing at 3.743 @stock volts and temps idle @40c ful load 50ish
will keep you gues informed
ibby that's an awesome 3.4C much better than mine http://www.xtremesystems.org/forums/...threadid=33593 sigh
My IC7 MAX-3 Died last night :(
Ive sent it back to the supplier
currently using DFI infinity 865PE
using the gat/Pat feature it is up to 3.75@stock volts,
time to due more tweaking :D
this is seriously not a bad mobo ..
ok, i can get 3.8 @ 1.7 volts (BIOS)
seems to be undervolting ... im waiting for my replacment now ...
Hey there ibby & eberyone else here, just thought I'd say hello to you all... this is my first post on here...
I recieved my SL793 3.4ghz Northy the other day. I bought it from someone on ebay.
It had never been used and arrived in a earing case (??) just loose and rattling around... (where it came from , god only knows ;) )
I didn't hold many hoeps for the Chips potential but OMG! its great!
I ran it for an hour at 200fsb, then 210, then 220, 230, 240... i was starting to get giddy but it wouldnt get stable at 250fsb (4250mhz).
However, I have now bumped up the vCore to 1.75v (No v.mods on my P4C800E-dlx yet) and it is rock stable at 245fsb :)
I don't know whether its gonna be worth/safe trying 1.8vCore to get 250fsb+
Whats your opinions?
http://service.futuremark.com/compare?2k1=7755704
cash man, what does it say your cpu is reciving under load in cpu z ?
Nice to see u and welcome
Been messing with this dfi mobo
and its not doing 2 bad .. its got up to 3.819 Mhz
and thats on stock volts Iam impressed with this cheap mobo
s cpuz screen
Hey cash,
welcome to XS bro. this is a very nice forum and a good place to find some "hard to find" information. good to see that you are broadning your horizon. ;)
my 3.4 hit a wall at 230fsb unfortuantly. :( good luck to all of you with 3.4's.
Hey bro ;) It's good to see so many familiar faces on here... Overclocking must be a small world after all!
Whats up with your Vapochill man?
Ibby> That is a screenie of the CPU under load... my mobo overvolts at idle and undervolts at load.
1.8vCore idle = 1.902 reported
1.8vCore load = 1.72 reported.
I need the Droop mod sharpish!
Hey Guys I'm a new guy to the forums :) I have intel setup my 3.40c Ghz well not run at 4.00c Ghz . I'm runing the IC7 MAX-3 mobo this is a good mobo:) ... I need help to get me at 4.00Ghz.... I like to post a pic of my setup on the forums... ?
right st of all, for us to help u mate u need to tell us
1)
what voltage u are running,
2)
what overclock have u achived
3)
what bios u are using
4)
what kind of cooling
5) and the full spec of your system,
ibby
Hey. I'm Runing a Koolance. setup It on my Abit-max-3 mobo The cpu is a 3.40 runing at 3.85 I have a Asus 9800xt card is runing a Cool-Matic ATi Cooler is on a Thermaltake Aquarius II liquid cooling setup. The bios is 14. My ram is OCZ two 512 4200. the timing is 2.5-4-4-8. The ram is ddrv 2.9. The vcore 1.65. my temp is 45 in bios.......
the screen shot of the 3.915 .. is that stable ?
have u gave it any more voltage on the core ?
I think Mr-Timbo must change your mem ratio and then I think you can overclock more
Hey. It run ok but not too stable. but I can run good at 3.85g 1.65.If i can run it at 4.00g. useing 1.75v is this good r not... :confused:
Hey FallenAngel. You play cs. This [0SC]mr-timbo:)
What is cs?
i can post and load windows 4 gig, but it isnt very stable
cs = counter strike .
what psu are u using #?
I never played that game, why the wuestion about CounterStrike?
My PSU as is in my sig is a NoiseBlocker 480W 2x Silentfan S2 <19dB, it's a Germany brand
Blacknoise/NoiseBlocker Shop site
you can choose english, though they are worse than me writing english, I live in Luxembourg but I don't understand german
I think these guys are the masters of silence, though I love Thermaltake and Enermax for their products
I have a Aspire 500W dual fan aluminum power supply. This is my setup.
I use 1.725 to oc my 2.4C into a 3.2 and I don't see a problem it's stable after 3dMark2k1 and other benchs, some games and then working in Photoshop, no prob till now, ey but is a 2.4 not a 3.4 so I dont knowQuote:
nice pic .. u know that cooler ontop of ur 9800 xt what is it called
and where did u get it from >?
Hey This is it. work good man :) http://www.pctoyland.com/Merchant2/m...egory_Code=csc
I have a SL793
This is a lackluster cpu... what a piece of shi7
