have we decided to swtich to F@H?
Nothing has been decided, but if people want to fold for this team either temporarily or permenantly the welcome mat is open ;) This forum does have two folding teams, see the announcement at the top of every forum:
http://www.xtremesystems.org/forums/...ouncementid=34
Regards
John.
Well I have some instability somewhere in my dual, still havent been able to figure out exactly where yet. Just started blue screening out of nowhere if I run 2 instances of F@H. Think its memory related honestly though. Although not 100% positive.
Either way, there are 2 instances running at At 50% each right now. Dual board, so its not much, but all I can get.
What work units are those ifmu?
Regards
John.
Work units? ah yea um, no clue honestly. I just run the command console version and let it do its thing, thats about it really.
How did that thing where you selected WU that used SSE work?
I put my laptop on the team, I'm going to help D2OL and this team.
jjcom
Welcome to the team jjcom :toast:
Regards
John.
My system is prime stable so my data should be good.
And welcome to the team gbomb944 :toast:
Regards
John.
Welcome reaperman :toast:
Regards
John.
Alright, what I'll be using:
Laptop Athlon XP 1800 whenever on. and I might test it out on some other rig.
@D2OL team, I will NOT be dropping D2OL. I will just be crunching/folding for both teams :)
jjcom
Figuered i had a machien that i ues just for e-mail, web, trillian and TV 24/7 .
I just put a p4 3.2e sl7e5 Press"hott" in and couldn't do it. it was runing @ 63c and the fan was @ 4800rpm's. Felt like i was back in the athlon days running a Valcano 5 again lol.
Anyways put my trusty 2.4c in. that has been on for over 1 1/2 year"s". Max uptime so far has been 63 days without restart. sometimes my power flickers making it shut down. But anyways
2.4c SL6WF 53c load stock cooler
P4P800 vdimm, vdroop
Kingston 3200 ch5 2-2-2-6 3.2v 2x256mb
Emermax 350
WD 30gig
ATI 9500 Pro flashed to 9700 Pro
ATI TV card
this has been very stable in the past year or so.
Hope this little putter can help out. It will be on 24/7.
Peace Nugz
Welcome to the team Nugz :toast:
Regards
John.
I'm putting my 2.8 P4 lappy on the team.
Welcome to the team DragonOrta :toast:
Got my system below folding...not using full resources as I've got it doing Prime95 as well.
Also have my laptop going at it. It's Mobile Athlon XP 2200+ with 768 RAM running full time on just F@H.
In fact, I think I'm already on the board.
Welcome to the team Onycho :toast:
Regards
John.
I just signed up to fold on team 36362. I have a wierd picture of a blob on my screen and it says frames completed 1/250. Is this all I have to do? Is there a way you can check the team and see if I am really doing anything? lol
You can close that screen once you have looked at it. When it gets to 250/250 it will send the unit and your points will show up.
There should be a red cog icon in systray, if you right click on that select status, you'll see all the stats options.
Regards
John.
i just set my old rig up folding
p4 2.6g
512 meg ram
9600xt
(first time i used this)
question: is this right? it says WU end time is 156 days 6hrs (ish) are they all like this cos if they are how sum of u got 100+ completed?
Hi Tiayth,
Welcome to the team :toast: .
There is definately something wrong with that completion time, but it is updated in real time so if you are using a very high percentage of cpu time the estimate will be based on the cpu time left for F@H at that instance.
If you post a copy of the log file here I'll take a look for you.
Regards
John.
i think its sorted now....its got 7500 frames in the wu and i think the first one was just taking a long time cos that took about 25 mins, but now its gone thru the next 85 quickly and the overall time has dropped to just over 1 day
Hey guys! Just joined today.. I just got a prommie mach 1 last week. I'm going to fold on my server box too.
How come it always stays at around 50% cpu usage? I'm using an 2.4c with HT so do I need to run two instances of it?
