very nice work, good luck on making it stable enough for sisoft!
VErY Nice
Most excellent...thats some setup and 2 get those 3's simply amazing:toast:
LV
Is there anything you can do with this? Or just screens? How does the system behave at, say 285?
xtremely insane shots these. Even if you can do nothing with it...still very, very "LastViking like" if you ask me :D Excellent job man ;)
http://upl.silentwhisper.net/uplfold...3fsb3dmark.jpg
That it not the highest i think...tryied 276.81fsb did 2/3 of the 3Dmark test before it kicked me back to windows. And the temp is fair away from the cpu-z screens...(out temp -14 when i did cpu-z, and +2 when i did 3DMark2001). i cane do sisoft @283fsb+"temp out +2" timings 11-4-4-3-2.5, And 279 with 11-2-2-2-2.0..maybe the memmory is stoping me know... :/ Vdimm @3.7v when i did sisoft.
http://upl.silentwhisper.net/uplfold...bsisiftcam.jpg
Max sisoft sandra with old Dfi LanParty Rev B"Rev 2" It´s Rip know...
I think i cane get higher with this board....I´m only nead good temp out first...This board is LanParty Rev B - Rev A
:worship: :worship: very impressive :worship: :worship:
wow, very nice, both of you. :D
whats the max prime stable?
As always LV, excellent work! Keep pushing it man, I wanna see 300! :D Good Luck.
http://upl.silentwhisper.net/uplfold...84dcsisoft.jpg
The temp was -+0 out and this is with the new board....When i did 283+ in sisoft with the another board the temp was -14-> out..So i think i will break 4400 Int when the temp drops out :)
Hmmm how high vdimm will bh5 take without dieing :P
Ooo very nice, now i really want an infinity to get me that 3gigz :)
I think you're pushing it's limit bud, although I have heard of atleast one person running his BH5 at 4.0volts for a little while, but I can't confirm if that ram disintegrated or not in the process. :PQuote:
Originally posted by Lastviking
Hmmm how high vdimm will bh5 take without dieing :P [/B]
Good luck though, worse case I can sell you some nasty BH6 ;).
Maybe if your pumping heaps of volts you'd need to have better cooling not jsut ordinary ramsinks.
A 80mm fan blowing over the should suffice.
I have already a 12cm fan blowing over the memmorys with coldair :)Quote:
so whats the highest prime stable?
I dont know yet ... have not so much time to test :/.. But without modds it was @255fsb+ "With the old board"Quote:
If it are so importent for you i will test it later...(Prime is one thing...,i don´t use coldair coling 24/7). So the prime thing is not so fair to run...and i dont need so high speed @24/7 use, i run the fans @ low speed in 24/7 so prime is not importent for me.
First thing i want to do is break 4400 Int in Sisoftsandra .. but i need beter airtemp out first....:/
:stick:
hehe ok , thx for replying :)
well im not sure if i should get an infinity or not, im not interested in short high ocs but 24/7 stable ocs, know what i mean? so thats why id like to know what the max 24/7 fsb oc is.
on my a7n8x rev2.0 i can boot at 260+ and bench at 250 but the max primestable is 235. do you think an infinity can run 250+ 24/7?
I think 250Fsb will not be a problem with good cooling on mosfetts and Nb @ Sb if you have good memmory..(255-264Fsb maybe in 24/7 use)...But if you get a bad ex then i don´t think you get so high but i have not seen so bad ex yet.Quote:
http://upl.silentwhisper.net/uplfold...zsisoft1gb.jpg
CPC:Disabled
The temp was not so good this day :/ .
But 1 Gb powa :):toast: :toast:
I am having strange problems using my new mobile with the also new LP B :(
I cannot get into windows with a fsb higher than 250 anymore... with 1-21. With 2-17 I could run 10x260 3DMark without problems, but it does not boot into windows at any higher frequency either :(
I think it's the cpu since I know the ram can take it...
It's posting with 270 or higher as well, but the cpu won't let me go into windows though. It just locks up on the win2k boot screen with the bar in mid position (but it varies)...
Gonna test another cpu 2night, maybe my locked one. It may help too doing the L12 mod again although it did do any good for my tbred... who knows.
Hi lastviking, what a great result....
I write also there:
I'm stopped at 263.68 Mhz (9x multiplier) 11/2.2/2/2/11/13
without mod...ram with BH5@3.26/3.28 (3.30 Bios)
vdd@1.7v
My 2100+ is without L12 mod ( ?????)
With vdimm mod and vcore+OVP mod I'haven't any gain in fsb
(I've also tryed vith 7X multiplier...)
In fact with 3.46v on vdimm and 1.8/1.9 on vdd (NB cooled with H2O at 0/2°), my mosfet are also cooled...)
I'm still at 263.68 !
Bios is 21/1/04
and I'would to know if there's a better bios...(link for 2-17 alpha?)
and the settings of dimm driving and strength
What fsb did you get to with 3.40/3.45 of vdimm?
how your NB and SB are cooled?
thanks in advance!
Hmm thats strange...And very bad....
