Outstanding piece of work,we all knew you would do it!!
This is the time to open that bottle!! :toast:
Congrats man!
Congrats man!
WTG Macci!
Peace
WannaGoFast
dam that's one hell of a clocked 9800XT :)
now i wanna see 11k:p: :stick: :toast: :D
Now pull that rig up next to OPP on the 2001 ORB.....those clocks are enough to maybe tie him.....if not you would be within 100 marks or so IMO...
I like an AMD on top of 2001 :DQuote:
But congrets to 10K in 2003 macci!
incredible.........just incredible
congrats Macci, for a job well done.
The 10k barrier has been broken.
it's Miller time!:toast:
http://imagehost.vendio.com/preview/...bad8e692d8.jpg
nice macci, can you update your compare and change the name to Felge ;---) :D ?
It´s time for norway to take a 1 place on orb :), Sweden have many 1 places with another cards and finland have macci"one and only macci"Quote:
GJ macci! :toast: :toast:
Pics of blown bridge? :D
Awesome!!
Congrats.
Well done !:slobber:
Have any of you considered the fact that R420 (or whatever it will eventually be called), has already taped out, and they have initial samples of these chips, and prototype boards.. meaning,
ATI engineers have probably broken 10k long ago, and probably have enough juice to allow us to OC to 12k... maybe even 13k. If ATI shrinks to 0.09u (and you can OC it to 1000Mhz+) then maybe even 20k!!
Very nice job Macci grats on the #1 :D :banana:
Thanks again for the kind words :)
blown:Quote:
http://www.akiba-pc.com/broken.jpg
fixed:
http://www.akiba-pc.com/e107_images/...cardhotfix.jpg
btw, with the fix it could take 657MHz at 2.43V Vgpu :D
a well deserved drink - like i said in the hall of fame thread.. biggo respect to you! :toast:Quote:
Originally posted by macci
Thanks for the support guys :toast:
It took some 6 days of benching and tweaking and modding but today I finally got it up and running at required MHz :)
It was 20secs from finishing the test at the same record breaking speeds last wednesday (4505/657/471) but then a bridge on the card exploded - 20secs before the result would have popped up!
I fixed it and Today I finally got it to the same speeds again.
Here's how the 10k hunt looked like in the ORB:
http://www.akiba-pc.com/e107_images/...rb_results.gif
10k rig:
http://www.akiba-pc.com/e107_images/...08_system3.jpg
I guess its time to open the bottle now :D :toast:
and the funniest thing - at least to me - is that the whole rig looks pretty clean and ordered, quite unlike the chaos i'd somehow expected (ignoring your 2 doomsday cascades that is).. but it has the looks of a plain lab-test - just the cables for the vmods hint at something completely different :D
now put your 9800se in that rig and make it 9.9k or more aswell! :D
Nice.
The little cap in the upper right sure looks like its getting hot...
real great work :)
grats!
my congras for the 4th time ;) very nice to see a 5 digit score! you have tons of fans cheering you on :D as for that pic you took of your rig, that was after you already published the score ;)
Haha,Quote:
fixed:
Maybe doing this "mod" on the card now from the beginning;)
Nice one Macci.
It looks like Macci just replaced the broken cap by soldering a tin lead to the resistor connectors.
As already mentioned several times, now you just have to use the same system setup for 3DMark2001... to catch-up/beat OPPainter...
BTW: I meant no offense by mentioning that ATI engineers have probably had 10k on their new chip... it just means that YOU'll probably be able to get 12-13k out of it (if not more.. you never know).
Maybe it's time for some really exteme cooling.. Have you considered liquid helium... it's very expensive but much colder.. if you can get close enough to zero kelvin, the superconducting chips should let you overclock a little more ;)
I dont think it was a Cap kanavit.
Anyways, that fix makes me so happy to look at. Its hilarious. :banana:
Won't work.Quote:
macci, are you ati beta driver tester?
There are some 64 bit cats out there!
nortwoods dont like temps below 110/120°C , no idear about gpus...
