Did you run prime 95 29.1 ?
I could bench run tasks fine...mission critical stability which i suspect would be intended use...not so fine heat wise not to mention it would throttle or crash due to heat...or hit thermal shutdown.
The power for hard forum jumped to double...so 400-500 watts of cooling @ 4.0 stress stable that was custom on a prototype TR block...
