Thank you for trying to help me Ace123 , apretiate it.
Finally I have an answer after many many long hours testing and re-testing my 290x with every driver available and 3 different OS w7 installations , card has not been volt moded yet. The problem is related to the video card throttling down during heaven , it does it 1340/1677Mhz stable and pass heaven DX11 extreme on water full cover EK H2O block , but the card starts throttling at test #11 once it gets warmed up the clocks goes up and down as well as the FPS ,performance take a nose dive due to the v.core set at 1.43v real via DMM reading , water cannot handle that much heat , LN2 required for stability. Big Thank You to Crustytheclown for all the help. I guess finally I found a Golden card , I am happy as a dog with 2 tails :D. next will be full volt mods and LN2 to make it scream.
Here is a short video I made of a complete run of heaven at 1340/1677Mhz on ambient temps H2O, I selected and only showed the last 2 test #25 and #26 because heaven last almost 5 minutes to run lol , the fps starts very strong from test 1 all the way until test 10 fps are 186 max , average 182 ,then it takes a big performance hit after test 11 once the card is warm game over :/. darn it took my 6 cards to find a golden one. watch the short video and the FPS. Check it out to see what I am talking about. id you are having the same problems as I did , there is your answer.
http://youtu.be/GQoXT319nvs
